Click for Nautical Structures
Click for Quantum
Click for Oceanco
Click for Queenship
Click For Affinity
Go Back   YachtForums.Com > GENERAL YACHTING DISCUSSION > Technical Discussion > Belzona aluminum repair product
Reply
Old 07-15-2009, 10:12 PM   #1
Capt. Bill11
Senior Member
Capt. Bill11's Avatar
This may be old news to some, but, on the aluminum boat I have recently taken over we found damage to the hull from some improperly stored lead ballast stored aft of the rudders. The hull in that area is 15mm thick and in some spots it was pitted to only 7mm thick. We were looking at having to cut out part of the hull and replace it. Estimated cost $15,000 to $20,000.
Then a friend told us about: http://belzona.com/products.aspx
http://belzona.com/marine.aspx
We made some calls and found out it was was ABS approved and would pass survey.
To make a long story short we had it done, it only took three days and the cost of the prep and repair came to under $5000!
Here are some pictures of the repaired areas.
http://i50.photobucket.com/albums/f3...e/balzone3.jpg
http://i50.photobucket.com/albums/f3...e/balzone5.jpg
http://i50.photobucket.com/albums/f3...e/balzone6.jpg
Capt. Bill11 is offline   Reply With Quote
Old 07-15-2009, 10:35 PM   #2
dennismc
Registered User
Is it a "paintable" type product, 2 part ?
dennismc is offline   Reply With Quote
Old 07-15-2009, 11:09 PM   #3
Capt. Bill11
Senior Member
After the metal was soda blasted they applied a structural material to fill the pits then over coated it with the more paint like product.
Reply
Thread Tools
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is Off
HTML code is Off
Forum Jump
All times are EST. The time now is 07:43 PM.
Click for Christensen
Click for FLIR
Click for Westport
Click for Moonen
Click for ISA
Click for Dyna
