| 1988 Crusader Engine Problem
Recently one of my engines had a busted choke cut-off, replaced that but then the engine was running poor while it was cold. I then replaced all the spark plugs (which the old ones almost had nothing left of them) engine ran much better, but still has some troubles when cold. I noticed when the engine is cold, that there is fuel pouring out of the fuel return line from the carburetor and the other engine has no signs of fuel return. Also, I took of the filter and looked into the carburetors on both engines. On the engine running fine I could barely see fuel injecting into it, but on the engine that is running poorly I see lots of fuel.
Any ideas…
