Click For Affinity
Click for Lurssen
Click for Platinum
Click For Affinity
Click for FLIR
Click for Nautical Structures
Go Back   YachtForums.Com > GENERAL YACHTING DISCUSSION > Technical Discussion > Vessel Management Software
Reply
Old 07-13-2009, 08:20 AM   #1
mulligan
Registered User
mulligan's Avatar
I'm just looking for a vessel management software. I got some demos from
IDEAS VIO www.ideayacht.com , MARINEWRIGHT which runs on PC and Apple Mac :-) www.marinewright.com and VMS Pro www.thegeneralistweb.com/sve_tourintro.htm .
So i'm not really sure which is the best ?
What are you guys using ?
Kai
mulligan is offline   Reply With Quote
Old 07-13-2009, 08:51 AM   #2
K1W1
Senior Member
K1W1's Avatar
Idea Software is my personal favourite owing to it's ease of setup and use plus the personal support of the creators.
__________________
Cheers,
K1W1
K1W1 is offline   Reply With Quote
Old 07-13-2009, 11:28 AM   #3
Rene GER
Senior Member
Rene GER's Avatar
What's about Seascape? Is this not a software for management or only monitoring?
__________________
Best Regards,
René
Rene GER is offline   Reply With Quote
Old 07-13-2009, 07:06 PM   #4
'roundthehorn
Registered User
'roundthehorn's Avatar
If you have a classed vessel you might want to check with that particluar society. American Bureau of Shipping offers software. Don't know if you need to be under their guidance to use it or not.
ABS Nautical Systems, LLC. - http://www.abs-ns.com/
'roundthehorn is offline   Reply With Quote
Old 07-14-2009, 10:25 AM   #5
mulligan
Registered User
mulligan's Avatar
IDEA VIO should be fine !!
After testing the several demos I got - I will go with IDEA. The only bad thing is i have to run it on windows - we have only MAC's onboard
Old 07-14-2009, 03:35 PM   #6
nilo
Senior Member
I am using IDEA for the last 3 years and I have also decided consulting extensively. I am happy with the choice I've made and I hope you will enjoy it as well.
nilo is offline   Reply With Quote
Old 07-20-2009, 04:34 AM   #7
Rene GER
Senior Member
Rene GER's Avatar
Can somebody tell me, what makes a good software?
There are wishes from the professionals, which no software can on the market?
What's about the trader reachability? Must there be a seller or an technican in the near of ship yard?
Is an 24h support important?
__________________
Best Regards,
René
Old 07-20-2009, 05:27 AM   #8
K1W1
Senior Member
K1W1's Avatar
A lot of the software used for inventory/maintenance and management is actually the same relational database- MS ACCESS with a different front end or GUI tacked onto it. For may users plain old Access is not easy to write to directly and furthermore is not really setup to do what the marine industry wants to do so this wee front end program ties up the loose ends and gives us ( hopefully) an easy to understand and use interface to the back office.
As for the supplier being near the yard- It depends on which one you go with, the big players generally have representatives all over the place and a lot of troubleshooting can be done online.
When I was first looking to buy an off the shelf one having spent a few years with a self written in FMPRO I became acutely aware that a lot of what the client was paying for was the development and application of this little front end program that controlled the DB. A number of the suppliers I spoke to and visited were smallish operations and none had made any provision as to what would happen to the source code for this GUI should the author pass away or the company go out of business bar one- That was one of the reasons I chose IDEA at the outset because they were very professional and upfront with all questions I asked. Other things that encouraged me to take this system was the experiences of two others who had (a) joined a boat that had it (b) chosen it for much the same reasons I did.
5 Yrs on I have not been disappointed or let down by this company.
__________________
Cheers,
K1W1
Old 07-20-2009, 05:32 AM   #9
Rene GER
Senior Member
Rene GER's Avatar
Thanks for this Information, K1W1
__________________
Best Regards,
René
Reply
Thread Tools
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is Off
HTML code is Off
Forum Jump
All times are EST. The time now is 09:17 AM.
Click for Dyna
Click for Oceanco
Click for Queenship
Click for Westport
Click For Dockwise
