Click for Westport Click for JetForums Privacy Matters Click for YF Listing Service Click for Ocean Alexander
saltwater to fresh
Discussion in 'Technical Discussion' started by gotta-float, Jul 7, 2009.
  1. gotta-float
    gotta-float New Member
    Dallas Texas
    I've looked trough the tech pages and didn't see anything on this. I'm consitering the purchase of an Sea Ray 40 Express Cruiser. Wondering about any problems with a saltwater to fresh water move for the boat? Thanks,Gotta-float
  2. CaptTom
    CaptTom Senior Member
    Palm Beach to Ft Lauderdale
    Welcome gotta-float,
    Usually, folks have problems when going from fresh to salt water.
    One thing to keep in mind is that once you go to the fresh side, corrosion can still occur because, most likely, there will be salt and/or corrosion still in place. Salt not only corrodes from the inside, but outside too. Not sure what year it is, but I think you definitely want to clean the engine room and engines. Spray from the shaft or stuffing box, busted raw water hose, leaky heat exchanger may have dumped salt water in the engine area.
    Also, I would change the impellers and wedges as you're not sure of their age.
    Good luck.
  3. gotta-float
    Dallas Texas
    Thanks ,CptnTom I'll keep this in mind
