Click for Platinum
Click for Nautical Structures
Click for Christensen
Click for Quantum
Click for Queenship
Click for FLIR
Go Back   YachtForums.Com > GENERAL YACHTING DISCUSSION > Technical Discussion > What type of GPS should I get?
Closed Thread
Old 07-06-2009, 01:26 PM   #1
AMC1096
Posts: n/a
Today I woke up on my boat and noticed that the GPS screen was broken. I hated the system anyway. I was then wondering what kind of GPS I should get. I want the most high tech and the best one on the market. I would like a GPS that has a feature to tell me where the marinas are. I am hoping you can help. I need help ASAP because I now can't use my boat. I was thinking about getting a Furuno NavNet 3D. Thanks
Old 07-06-2009, 01:47 PM   #2
AMG
YF Moderator
AMG's Avatar
Quote:
Originally Posted by AMC1096
I need help ASAP because I now can't use my boat.Thanks
My best advice is to sell the boat, or learn navigation...
AMG is offline
Old 07-06-2009, 01:48 PM   #3
Kevin
YF Moderator
Kevin's Avatar
AMC,
I've moved your question to the Techinical Discussion forum since it fits in better as a technical issue, not a FAQ.
Kevin is online now
Old 07-06-2009, 01:59 PM   #4
AMC1096
Posts: n/a
No No. I am looking for a new GPS and I need some advice.
Old 07-06-2009, 02:03 PM   #5
Kevin
YF Moderator
Kevin's Avatar
That's the purpose of the Technical section:
Quote:
Engines, Electronics and things that break!
Kevin is online now
Old 07-06-2009, 03:03 PM   #6
K1W1
Senior Member
K1W1's Avatar
If you are a boat Owner and Captain all rolled into one then I am wondering what sort of qualifications or experience you have to actually move the boat if you say you cannot move it without GPS.
I know So Fl is pretty flat but there are a lot of things that stick up and can be seen for a few miles up and down the coast and offshore.
If you want to go north either stay in the ICW or if venturing outside keep the land on the left ( port) going south keep it on the right (stbd)
I have not seen a GPS as such that shows Marinas the way an Automotive one shows Gas Stations, there are however a lot of combined Chart Plotters and GPS's that have very detailed maps that would probably suit your needs.
I like the current Raymarine lineup for small boats myself.
__________________
Cheers,
K1W1
K1W1 is offline
Old 07-06-2009, 03:13 PM   #7
SeaEric
YF Historian
SeaEric's Avatar
I like the Garmin units. They are economical to buy, simple to use, and have the marina and other info you're looking for.
I do agree with Lars that some basic understanding of navigation using paper charts is a good idea before setting sail. Its pretty easy to learn. It would be nice to be able to get yourself home if the electronics fail you. And, they likely will at some point. Like now.
SeaEric is offline
Old 07-06-2009, 05:27 PM   #8
NYCAP123
Senior Member
NYCAP123's Avatar
PLEASE learn navigation and how to use charts. Murphy's law dictates that your electronics will go down at the worst possible time.
What size boat you have will have a great bearing on what unit you should get. Also, will you be combining it with radar. If so you want the largest screen you can fit. I've worked extensively with Furuno navnet. Very good units. Most charplotters today have a click on feature that will give you info on marinas, etc. but it's really easier to use a cruising guide. The pictures are nice but I have never found a need for them. The weather feature on some is nice, but I've found more useful info by turning my radar out to 12 or 24 miles.
In other words don't go buying the latest and greatest gizmos if you're not going to use them. Check to see how easy it is to change the data fields to info you'll find useful. Make sure it is easily read in bright sunlight. Is it easy to navigate between screens and tasks? Can you easily pull up tide info. All the gizmos in the world are useless if you can't access them quickly and easily while running. Also, how many routes does it hold and how many waypoints will it allow you to put into a route? If you have a boat that does more than 20 knots you'll probably want to forget about touchscreen as it gets rediculous trying to put in a quick waypoint on the fly.
My personal favorites for GPS/chartplotters are Garmin, Furuno and Raymarine in that order. I recently read an article on a guy who had to have the latest gizmos. His GPS/chartplotter/Radar would crash for about 5 minutes every 2 hours and he considered that acceptable. Me, I'd be burning up someone's phone line.
__________________
"Some went down to the sea in ships."
NYCAP123 is online now
Old 07-06-2009, 05:30 PM   #9
Capt. Bill11
Senior Member
Capt. Bill11's Avatar
I've used most all of them at one time or another. I like Raymarine stuff but they seem to be in a bit of financial trouble from what I've read.
Your best bet is to go look at the different units and touch and feel them and learn about there features to see what suits your needs. Garmin makes nice stuff as does Furuno.
What size and type boat are we talking about here?
Capt. Bill11 is offline
Old 07-06-2009, 05:44 PM   #10
AMC1096
Posts: n/a
The size of my boat is 183' and is made by the company Burger. I also like the Garmin GPS. It might be good for the size of my yacht.
Old 07-06-2009, 05:55 PM   #11
NYCAP123
Senior Member
NYCAP123's Avatar
The size of my boat is 183' and is made by the comapny Burger. I also like the Garmin GPS. It might be good for the size of my yacht.
1) When did Burger ever make a 183' yacht
2) The owner of a 183' yacht should be taking the advice of its captain and engineer.
__________________
Old 07-06-2009, 06:00 PM   #12
AMC1096
Posts: n/a
Burger makes custom yachts. I am also the owner/captain of my yacht.
Old 07-06-2009, 06:14 PM   #13
AMG
YF Moderator
AMG's Avatar
It must be this one..?
AMG is offline
Closed Thread
Thread Tools
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is Off
HTML code is Off
Forum Jump
All times are EST. The time now is 09:01 AM.
Click for Dyna
Click For Dockwise
Click for Moonen
Click for Horizon
Click for Heesen
Click For Affinity
