Click for Dyna
Click For Affinity
Click for Queenship
Click for Westport
Click for Crescent
Click for Cheoy Lee
Go Back   YachtForums.Com > GENERAL YACHTING DISCUSSION > Technical Discussion > CR900 Man Engines smoking
Reply
Old 06-11-2009, 10:36 PM   #1
CSkipR
Registered User
My Man engines have started blowing dark smoke when accelerating. They only have 400 hrs and this has just started in the last 25 hrs.
CSkipR is offline   Reply With Quote
Old 06-11-2009, 11:44 PM   #2
Capt J
Senior Member
Quote:
Check/change your fuel filters. If the engines are overpropped they will smoke heavily. Make sure you're hitting recommended top rpm's......Could also be a turbo issue or injectors, but check fuel filters first especially if it only recently started. It can also be growth on the bottom and running gear
Capt J is offline   Reply With Quote
Old 06-12-2009, 10:38 AM   #3
NYCAP123
Senior Member
NYCAP123's Avatar
All good points CaptJ. At 400 hours you're right at a point where you should be changing oil, filters, etc. Has this problem continued after these changes?One thought; that area of the ICW like most of Florida is one big idle speed zone. RU getting these motors up to cruise speed often enough to avoid carbon build up. You may have to change injectors.
__________________
"Some went down to the sea in ships."
NYCAP123 is online now   Reply With Quote
Old 06-16-2009, 10:14 AM   #4
CSkipR
Registered User
Man 900 smoking
Quote:
I changed the fuel filters and cleaned the K&N filters. The fuel filters were pretty dirty so that could be the problem. They were changed about 50 hrs ago but I am in the Bahamas and have refueled several times so that could be the problem. Will check it out today.
Changed oil approx 100 hrs ago but will change when I get home. Also have to have the heads retorqued & the heat exchangers cleaned.
Reply
Thread Tools
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is Off
HTML code is Off
Forum Jump
All times are EST. The time now is 05:58 PM.
Click for MCC
Click for FLIR
Click for Heesen
Click for Moonen
Click for Platinum
Click for Lurssen
