Click for Westport Click for Nordhavn Click for Glendinning Click for Burger Click for Abeking
Azimut window etching
Discussion in 'Technical Discussion' started by sagharborskip, May 31, 2009.
  1. sagharborskip
    sagharborskip Senior Member
    Sag Harbor, NY
    55' Azimut has badly etched windows presumably from hard water. There is a sticker on windows that says "Do not use abrasive". I gather the Azimut applies the tint to the OUTSIDE of the windows??? (WHY???)
    I've been compounding the gel coat the last few days and have been careful not to wheel the windows...
    However, I tried the wheel on a small bit of the window with no compound except for what was left on the pad after raking pad pretty thoroughly and got amazing result on the window as it removed all the etching with apparently no ill effect on the tint.
    Anyone care to input on what might happen if I continue with the wheel? We also put a little Finesse-It on a rag and tried that and that worked as well.
    A little help...thanks!
  2. AMG
    Most of the tinted glass you see is laminated with a colored film in between the layers. But the kind of mirror effect some of them have, may be applied outside..?
    Since you have found a way of "cleaning" it, why don´t you continue? On windows with marks of calcium, you may use lemon or vinegar to remove it. To avoid it, never wash down the boat in sunshine.
  3. CODOG
    CODOG Senior Member
    Bournemouth, southern England
    Cant speak for Azimut (e-mail them and ask) but its very unlikely that tinting film is applied to the outside face of exterior glass. Tinting film is common, but on the inside face....for obvious reasons.
    Most European glass plants (Isoclima, Taylor-Made / Trend (Ireland and England) etc.) can supply monolithic and laminated glass that is self tinted. Either smoked tint or mirrored tint. There are also a few forms of 'solar gain' glass that is laminated with a smoked / mirrored tinted layer within that is effective in cutting out UV and heat. The warning not to use abrasives is very common....glass will scratch and get dull with a lot of commonly used polishes.
  4. AMG
    You are right CODOG, we were using tempered single glass that is coloured on our smallest boats, before we started with DNV classification. Azimut seems to deliver tempered, not laminated, glass as well.
    These days you can have laminated and chemical toughened glass which is very good when windows are becoming a part of the structure.
  5. CSkipR
    CSkipR Member
    New Smyrna Beach, Fl
    AMG,
    I have tried lemon juice with little or no success. Will give vinegar a try. I have bought a number of different products to remove hard water stains with little success. Even using a buffer.
  6. GFC
    GFC Senior Member
    Tri Cities, WA
    I've used a product called C-L-R to remove water spots and etching on my boat with success.
  7. Capt Bill11
    Capt Bill11 Senior Member
    Sarasota/Ft. Lauderdale FL
    As noted, try CLR or Wink Rust Remove. Even mild acid based toilet bowl cleaner will work.
    And as you have found you can polish glass if you're carefull.
    To keep it from happening again seal it with Zaino, Rain-X or Aquapel.
  8. sagharborskip
    Sag Harbor, NY
    Whink!
    Thanks for help, whink does the trick. Terry cloth towel, thoroughly wetted window with Whink, gentle scrubbing and no more etching...
    Will use window protector (Rain-x) but didn't want to trap the etching under the Rain-x...
    Thanks, again.
  9. Nudibranch
    Nudibranch New Member
    Northland, New Zealand
    Hey Sagharborskip,
    We learn't the hard way with our previous yacht. Water left on the windows was bad. We now 'squeegy' our Azimut windows dry after we've washed the boat down with a hand held squeegy blade to prevent or at least prolong the event of window glass etching.
    best of luck!
  10. Henning
    Henning Senior Member
    Ft Lauderdale FL
    The "no abrasives" warning is because it's tempered glass and scratches alter the surface tension which alters the strength and that can lead to the window turning into 10,000 tiny bits of glass with an impact much less than it is required to endure. Who in the hell ever thought of putting big windows in a hull near the waterline....:confused: :eek: :(
  11. NYCAP123
    It looks pretty. Isn't that priority One for yacht building today.
  12. Fishtigua
    Fishtigua Senior Member
    Guernsey/Antigua
    Errr......that is the waterline these days.
    Where do you put the fenders? Will the windows push in? Do you want to sleep in a cabin with all the allure of a basement apartment on a busy street when in the marina?
    http://azimut53.****************/
  13. NYCAP123
    Years ago I awoke at 0500 and my tired eyes immediately focused on the TV screen with a reflexion of a wave going past my porthole on it. That was all she wrote for the next 18 hours :( . Can't imagine what the alure is of waking up with a big window right at water level. Alot of people must be going to sleep with a Dramamine IV drip. Hey, but it looks cool at the shows right.:confused:
  14. CSkipR
    CSkipR Member
    Did the Whink Rust Remover really work that well on the windows. I have tried just about everything with minimum results. Will have to give it a try.
  15. Capt J
    Whink does an excellent job. Do not use whink in direct sunlight on the glass or if the glass is really hot. Thoroughly wet a few paper towels (folded) rub in a circular motion (at a normal slower speed) and I do a no more then a 2'x2' area at a time.......when you see the droplets dissappear and the whink is smooth, do it for 10 more seconds and then immediately dry the whink off with a dry towel or paper towels..... if it dries on there it's much harder to remove.......when the window is done, put rain-x on it........ whink works great......
    OHHH Use gloves because whink will seriously dry out the skin on your hands.......
  16. K1W1
    I was riding on a 70m Yacht a couple of years back with the biggest windows in the guest cabins that Class would allow. I was in a guest cabin and laying in bed I was just a bit above the water. It was a great way to be lulled to sleep.
    This cabin also had a bath and it is a strange experience having a soak whilst underway especially when you put your head under water and can hear a lot of things you couldn't when your head was above the water.
  17. NYCAP123
    Years ago housekeepers developed a phrase: "I don't do windows". Designer's response was to build bigger windows and tint them dark so they'll show as much as a shiny black hull. Finally, they put them near the waterline were they'll get a 30kt blasting of salt water and put a sticker on saying "Do not use abrasive". I seem to recall a line from a poem but don't remember the author it went something like 'give me a ship, a stout hardy ship, and I will sail the seas'. Must have been written in the days before the "Metro-sexual".:rolleyes:
  18. CSkipR
    CSkipR Member
    Whink Rust Remover - Great Stuff
    Wow that is the first product that I have tried that really does the job. Tried vinegar, lemon juice, CLR, and a few other hard water stain removers with little to no success. Whink did the job. I put RainX on after cleaning.
