Click for Westport Click for Ocean Alexander Click for Cross Click for Abeking Click for YF Listing Service
16v96
Discussion in 'Engines' started by Manny, May 16, 2009.
  1. Manny
    Manny Senior Member
    Puerto Rico
    Does anyone know of this DD engine? I have a friend that repowered his 61' Buddy Davis from 16v92's to the 19v96, and I'm curious about this engine I haven't heard of. My friend said his boat cruises the same speed as with the 92's but burns half from what the 92's use. Is this true? any other info?
    thanks
  2. K1W1
    You have posted 16v96 in the title and 19v96 in the thread.
    I do not know of any DD with this model designation.
    There is an older MTU Engine that is a 16V396 which was popular a few years ago.
  3. CODOG
    CODOG Senior Member
    Bournemouth, southern England
    It's most likely a 16v92 with increased capacity. Heres a link to a company who replace the 16v92 crankshaft to do this, and call it a 16v96.
    http://www.jackbivens.com/home.html
    Buddy Davis is listed as a recipient of this modified engine.
  4. K1W1
    Pretty interesting link there, thanks for sharing it.
  5. VikHatBer
    VikHatBer New Member
    Miami, FL and the Keys
    2475 RPM??? How common are parts for these V96 series motors?
    It doesnt seem realistic.
  6. Manny
    Manny Senior Member
    Puerto Rico
    It's actually very real, otherwise the engines my friend has on his Buddy Davis are mystical engines that came from the sky. He showed me the HP, fuel usage, and highest RPM's. I may actually consider upgrading my engines to the v96 series if it's possible.
    Well with a stronger crankshaft, there is no reason you couldn't turn the engine more RPM's as long as the other components are strong enough such as piston rods, pistons, rocker arms and such. They do it with gasoline engines all of the time by stroking them and/or boring them. I don't know how long term durability is.
  8. K1W1
    Not an unknown phenomenon in the aircraft industry:D
    It is not so much a stronger crank it is the throw that is altered to increase the stroke from what I understand.
    As for parts commonality- Why not ask the dude who builds them and get the answers from source.
  9. Manny
    Manny Senior Member
    Puerto Rico
    Would anyone happen to know if the 92's can be upgraded to v96's while mounted on the boat or do the engines have to be removed to do the upgrade?
    I'd ask the people from the website but I don't want them inquiring me to do the upgrade right away. I'm only considering.
    thanks
  10. CODOG
    CODOG Senior Member
    Increased power, increased torque (presumably) and increased RPM....all have a knock on effect on gearbox ratios / torque rating, shaft diameter / props.
  11. K1W1
    I am pretty sure that they would have to come out and probably go to these guys workshop to get that conversion.
  12. Loren Schweizer
    Coral Gables/Ft. Laud., FL
    More horsepower? With more displacement, seems likely.
    But less fuel consumption? Ooookaaaayyy.....
    Less engine wear/longer engine life? Lessee....the pistons travel a longer stroke (twice) per each revolution and turn the same rpm (or more? 2475?) which means that there is a higher piston speed at work here which should equal more heat & wear. Hmmm.
    I would suspicion omission of a ringset or two (a hotrodder's trick) and/or additional modifications to the fuel/air delivery systems (modded chip in the DDEC ecu, maybe).
    Not purely a 'stroker', but with some pixie dust mixed in as regards the builder's claims?
  13. boblucas
    boblucas New Member
    Stuart Fl, Brielle, NJ
    Actually, Jackie Bivens took some 92 series Detroits and bored them to 96's. He did it with 8's, 12's and 16's. He then used a different custom cam and pistons. They developed more HP and seemed to stay to gether quite well. I'm pretty sure Jackie is still around. I had a client that surveyed a Rybovich with the 8V96's several years ago and Jackie did the engine survey. (Not my choice).
  14. Loren Schweizer
    According to Mr. Biven's own website, a replacement crankshaft results in the additional cubes...plus, these are linered bores which would obviate the possibility/need to bore them out, IMHO.
  15. boblucas
    boblucas New Member
    Wasn't aware of that. I just know that the 92 and 96 represents cu inch/cyl. in the Detroits. I guess the longer stroke got the xtra cubes. Oh well.
  16. rgsuspsa
    rgsuspsa Member
    Melbourne, FL
    The V96 engines are modified to 96 cubic inches per cylinder by
    All World Power Corporation,www.jackbivens.com, located in Stuart, FL.
    Mr. Bivens passed away on 12 May of this year. His son continues to run the business.
    rgsuspsa
  17. Bamboo
    Bamboo Senior Member
    Palm Beach, FL
    I spoke with Jack's son who is running the business. It's headquartered next to ACY in Stuart, FL. They have a set of 16-96's ready to be installed in a vessel now. It's quicker to remove and replace than to rebuild/change inside the engine room. It's normal in many applications to see a reduction in fuel usage at the same speed when you alter the HP of the original diesel engine. On road this is expected- no reason you'd see anything different here so the claim of less fuel used sounds reasonable.
  18. Capt J
    This may be true. But if I was going to go through the trouble of changing engines, I'd end up putting new engines with modern technology rather then modified dinosaurs.
  19. Manny
    Manny Senior Member
    Puerto Rico
    so it's possible to make the modification while the engines are in the engineroom?
    It may be quicker to replace, but I'm sure it's much cheaper to modify while the engines are still in, seeing as you would have to buy the new 96 series engines which will just be extra cash you want to spend, as well as what it would cost to move the old engine out and the new engine in, along with other factors...
  20. RER
    RER Senior Member
    Newport Beach CA
    If any variation of the word "cheap" is in your equation I'd skip the whole thing.
