Click for Westport Click for Walker Privacy Matters Click for Nordhavn Click for Cross
Engine room systems design parameters (safety.)
Discussion in 'Technical Discussion' started by RobVer, May 8, 2009.
  1. RobVer
    RobVer New Member
    Monaco
    How many realise that any vessel over 25m MUST have a gravity fed main-engine fuel system (day tank or self-replenishing type), and that it is an absolute requirement by Lloyds as well as most certification societies? How many realise why and how this affects basic safety, as well as half a dozen other elements of operation?
    How many know and understand the actual parameters of legal engine room ventilation systems and that these also affect insurance status. How many know why these rules exist? Or that the majority of yachts do not comply, even though the legal systems are usually cheaper to construct?
    As, amongst other things, a surveyor, I see that many in the yacht construction industry have, and are still being, either horribly cynical, naive, or wholly negligent (and stupid) by not adhering to these absolutely basic safety design parameters, and I'm tired of being expected to ignore the rules.
    There seem to be about a dozen areas where required design parameters are being ignored completely on supposedly 'quality' new yachts, sometimes all of them on one vessel, and yet they still get an MCA sticker.
    The problem has always been endemic in US and 'southern European' vessels, and has now even appeared on one or two vessels from younger Northern European companies. This is the last straw. I trusted the low countries!
    I believe it's about time that real yard-engineers and older wiser (sea-time experienced) designers, engineers and captains started to make a noise.
    So this is to ask if other's have noticed this over the years, or even care, and, if so, anyone would like to get together (initially over a beer, not a boardroom table) and do something about it?
  2. AMG
    Are you saying that yachts built to Lloyds classification doesn´t comply? Or that less yachts are built to class?
  3. Marmot
    Did you whack yourself with your little hammer?
    It's illegal to have a gravity feed for petrol fueled engines so that takes care of the "any" clause. Would you care to provide chapter and verse to support this bizarre contention?
  4. RobVer
    RobVer New Member
    Monaco
    I have found that many yachts, supposedly complying, are nowhere near as far as e.r. systems parameters are concerned. Further, have found most inspectors totally unaware of the problems or their possible consequences.
    Maybe one should point out that, in general terms, the noted German and Dutch yards know what they are doing and rarely make these mistakes.
  5. RobVer
    RobVer New Member
    Monaco
    Why the sarcasm? Is this not considered a serious enough subject? Quite obviously, in relation to fuel supply, one is referring to compression ignition engines in vessels over 25m. As for sneering at one's use of the word 'any'; suggest you read the pertinent sections and you will see that Lloyds, quite understandably I feel, seem to have made the same miniscule error.
  6. Marmot
    Please reference the class rules that support your position.
  7. RobVer
    RobVer New Member
    Monaco
    Lloyds syndicates .... (something.)
    Agreements on marine construction...(etc.)
    Power driven vessels over ... (etc.)
    Post bunkers fuel supply and control systems....
    Was part of your engineering syllabus.
  8. Marmot
    Blah blah blah, please post the relevent rule(s) the same way you would write it up in your survey.
  9. RobVer
    RobVer New Member
    Monaco
    First, I posted this to open a serious professional discussion, not a competition in smart answers.
    Second, the 'regulations' as such, either insurance or industry, probably weigh about a ton and I hold only a very few dog eared copied pages of the relevant sections from past chiefs, masters and my school days at Warsach etc.
    Third, the point does not dispute the rules correctness or not. Nor their efficacy. The latter has been 'evolved' by better men than me over half a century or more, and it was those men, some of whom did not survive the process, that pushed for E.R. parameters to be updated.
    My point is simply to ask why, today, commercial (cargo carrying etc.) ships are built to one tried and tested standard while yachts (ie. people carrying.) , except by those yards in Holland, Germany and a few other places, seem to be able to constructed completely outside the standard parameters and still be considered (and certified) as safe. Does nobody else notice this?
  10. rocdiver
    rocdiver Senior Member
    Ft Lauderdale, Florida
    I know I'm a little slow but you mention gravity fed and how it affects safety.
    Call me crazy but, it seems that in the unfortunate event of a failure of any of the MANY lines which transport fuel to the various engine components (and also return unused fuel) that I would rather NOT have gravity continue to feed said fuel into my engine room bilge, even though the engines might not even be fired at the time.
    Am I missing something here?
  11. AMG
    Well, I have no access to the rules about this here, but I had the impression this was half the idea of a day-tank?
  12. RobVer
    RobVer New Member
    Monaco
    This forum was really for marine engineers. But to answer your question in simplest possible terms, gravity supply provides numerous safety advantages such as instant starting (essential in the days of direct drive.), impossibility of air ingress into system, initial fuel settlement, accurate usage calibration, accurate fuel quality control checking, instant bleeding etc.
    There are numerous other practical advantages as well, but these are too many really to list here.
    The fire issue is not really an issue and, surprisingly, the manifold complexity is usually less than seen on (incorrect) constant suction supply type.
    Hope this helps. But as I mentioned, this forum was really to ask engineers etc. if something should be done to correct the slackness in the construction certification.
  13. Marmot
    First you have to show what regulations are not followed. You are the one who came here claiming there are safety issues because vessels over 25m (?) are not being built or delivered in compliance with class rules.
    What rules are you talking about? If you are a surveyor and find a nonconformity then surely you can reference the regulation or requirement that created it. That is all I am asking you to do. If you are a surveyor, part of your tool kit is (or had better be) a working knowledge of the class rules and flag requirements so you can ensure adherence in the course of a survey ... don't come back to me claiming you can't find them or you have too many books to locate them.
    What was the point of your original post anyway if you can't or won't provide concise details on what you are whining about?
  14. RobVer
    RobVer New Member
    Monaco
    Yes, sort of, if we are only discussing day tanks. Gravity feed (ie. lack of air in system.) is just one of numerous safety and practical advantages, not the least of which is the engineers proper practical control of the main engine to get a reliable supply of clean fuel.
    This is not about the rules. It's about practical everyday safety. I only used the rules to point out that if Lloyds demand it, it's probably worth considering.
    But I also now regularly see stuff like incorrectly panelled deck-heads (to hide wiring etc. one supposes.), air supply systems that blow (sometimes salty) air onto engines instead of sucking off the hot, feedways that terminate above the bilge, negative engine room pressures, incorrectly installed fire systems, plastic pneumatic shut off control lines, programmable main engine control systems without bypasses.etc.
    The list goes on and on and, sometimes, there are eight or ten of these basics on the same CERTIFIED boat!
    It's like betting on an inside royal flush, never mind a straight.
    ..and I keep finding 'day tanks' below the injections systems....and sized so as to require constant replenishment ..... maybe someone could explain to this old fool the advantage in that?
  15. RobVer
    RobVer New Member
    Monaco
    Listen, I don't know all the ****ed rules in my head, only those sections that have been written in stone, and which I've been using, since Christendom. And I don't admire your tone that suggests some dishonesty on my part.
    The 'rules' are not the point.
    The simple point is that the e.r. installation and systems engineering in 'yacht' yards, seems to totally ignore most of the fundamental RULES and if it's a good idea, or not, just to leave it that way.
    Or if anyone cares.
    If you can't bring positive discussion to that discussion, then please ignore it. And if you want to read the exact regulations, the Lloyds syndicates full definitions included, word for word to check my veracity, then call Ince and Co in London and ask them. But to any engineer, most installation parameters are tried and tested common sense, and he doesn't need to carry about the bible to do his job.
  16. PropBet
    PropBet Senior Member
    Is Everything!
    Actually, the 'rules' you are quoting from Lloyds (or whomever) are the *very* point.
    Several have asked you to provide reference to your initial post.
    If you're going to quote something, and attempt to engage in a relevant discussion on it, please provide a reference to it. That's all that's being asked.
    If you have hard copies, the document name, publication, date, etc.
    If it's online, then a link to said rule or regulation.
    In contrast, if I started a thread that said the USCG now requires *all* vessels over 25' to be equipped with a _________ (insert absurd item here) wouldn't you want a reference to it?
  17. RobVer
    RobVer New Member
    Monaco
    I already answered this question. I don't store the entire Lloyds construction regs here. I also don't store the entire Monaco traffic regulations in my car ... but I happen to know it's 100% legal for me to drive without a seat belt here. Get it?
    If you don't BELIEVE me then OK ... ignore me. And I'm not about to do proven notarial due diligence into regulations for those I'm just trying to advise on safety.
    This is a SAFETY ISSUE. The POINT IS that many (in my mind the majority) of yachts presently being produced outside northern Europe seem to be ignoring MANY of age old fundamental safety design parameters that have been developed over many, many years, and are STILL getting certified.
    And yet this happens rarely in commercial shipyards. Why? Does anyone care, or is image and the naive client's money now everything, even to the classification auditors?
    I apologise if my English is such that I gave the impression that the rules were the issue. They were not. I meant to use them only as an eye opener to the problem.
    Lloyds rules are often sometimes over-stringent, and sometimes seem even designed to trip up claimants.
    But the fact remains that most societies (..not RINA ... unsurprisingly.) have long demanded similar systems parameters for a very good reason.
  18. PropBet
    Is Everything!
    OK, have it your way.
    Good luck with your conversation. I'm sure it will be scintillating.
  19. RobVer
    RobVer New Member
    Monaco
    Sarcasm? Is it immoral or in some way wrong to want to discuss and focus on an increasingly problematic safety issue with other engineers? Sorry, I don't get it. But then that wouldn't be the first time.
  20. PropBet
    Is Everything!
    No, it's not sarcasm. It's saying quite politely, that if you're so hard headed about providing a reference to the claim you make in your OP, and you continue to lash out at others who have asked for the same reference in that each person is thereby debating with you, calling you a liar, sarcastic, etc. etc. etc. all the while you fail to provide any reference whatsoever to the claim you make.... I say... very politely... good luck with your conversation.
    I hope it turns out well for you. I'm sure it will be more than fulfilling.
    I, as well as many others (those of whom are quite well educated, far more than I am) all of which have the potential to engage in the conversation with you at a level of intellect, you have essentially shunned yourself with said reference (all of which, asked for it).
    Good Day, Sir.
