Click for YF Listing Service Click for Burger Click for Northern Lights Click for Westport Click for JetForums
Teak flooring
Discussion in 'Technical Discussion' started by FabianAndrades, Apr 29, 2009.
  1. FabianAndrades
    FabianAndrades New Member
    Miami Beach
    Hello everyone; we just got a 66 Manhattan into our maintenance fleet and need some help with the teak flooring maintenance.
    It seems to have been well maintained, but it does have that "dry look" on it. The owner wants it to look more alive, and we really don't have much experience on teak treatments. Should I sub somebody to do it ?? I am very hands on person on everything we do, but don't really want to experiment on this vessel.
    All suggestions will be highly appreciated
    If you're in the business of maintaining boats teak is part of the job, and it's not a lot of work. Starbrite has a good, mild teak cleaner (if needed). Tip Top teak oil has a nice golden look.
  3. Ken Bracewell
    Ken Bracewell Senior Member
    Somewhere Sunny
    If there is raised grain, a light sanding will make it look new.
    Other wise, use Sudsy Ammonia (cleaner) and Teak Part 2 (brightener)
  4. JWY
    JWY Senior Member
    Teak Maintenance
    Don't forget to wash across the grain and don't use power wash.
    Judy
  5. Capt Bill11
    Capt Bill11 Senior Member
    Sarasota/Ft. Lauderdale FL
    Here's my home made two part teak cleaner recipe if the teak needs a good deep cleaning to start with.
    Just mix 1 cup TSP (trisodium phosphate, available at most hardware stores in white powder form) and 1-3 cups ammonia with 3-4 gallons of fresh water. That is your #1.
    Wet the teak and scrub across the grain using a Doodle Bug pad with the #1. Keep teak and surrounding areas wet but do NOT wash off #1.
    Mix 2-3 cups muratic acid with 3-4 gallons fresh water. That is your #2.
    Spread the #2 on to the teak and lightly scrub with a soft brush head. Again trying to scrub across the grain as much as possible. The teak will go blond as the acid reacts to the #1.
    Be sure to get the #2 on all the teak that has been scrubbed with the #1.
    After you have lightly scrubbed down all the teak with the #2 rinse everything off very, very well.
    Since you mix this yourself you can delute it down to any strength you wish and it costs
    about one tenth or less of the permixed kits.
    It should go without saying that you should use hand, eye and body protection when using this
    or any other harsh cleaner.
    And it should not be used to clean the teak on a regular basis.
    For everyday cleaning I like Oxalic acid crystals. Otherwise known as wood bleach.
    If the grain and/or seams are raised up, then it is time to sand.
    And IMHO, oiling decks just ends up being a PITA and makes more maintenance headaches in the long run. I like just keeping them clean and natural.
  6. NYCAP123
    a) How big is your boat?:eek:
    b) With all that work, no wonder you find it a PITA. ;)
    c) With all the commercially available and tested stuff on the market why play chemist?
    d) Whenever I hear 'sand' I'm reminded of a neighbor (who I didn't like) that I watched power sand his teak; then oil it. It looked beautiful until the first rain storm when all the oil just washed off with no grain to hold it. I'd been taught to only use bronze wool.
  7. Capt Bill11
    a) 90 feet with no teak. Yet.
    b) No more work than using a store bought two part cleaner. And I don't know anybody who doesn't think keeping a teak deck oiled isn't a PITA. That might be why you rarely see one. :D
    c) To save money.
    d) Good luck sanding down a worn teak deck with raised caulking with bronze wool. ;)
    Little or no extra work. You just mix and then scrub, like any two part cleaner. And making your own cleaner saves you and/or the boss some money. And the products you use to make the cleaner can be used for other things. Besides, many marine cleaners are just repackaged and way over priced house hold or institutional products.
    Oil shouldn't need any grain to hold it to the teak. It should soak into the wood not sit on it.
    And the smoother the wood the easier it is to keep clean. IMO, oil just attracts dirt and turns moldy looking.
  8. NYCAP123
    Fortunately, I don't deal with teak too often. The main boat I've been working has only the cockpit and swim platform so excuse my ignorance in this. What I'd learned (from the old dudes when I was a young dude) was that oil soaks into the pores in the wood. If you sand it smooth there are no pores to absorb the oil. The idea of sanding with bronze or brass wool is to clean the pores without taking any but the lose wood grain.
  9. Capt Bill11
    Count yourself lucky. I managed a charter fleet of up to 12 or so Grand Banks for 15 years. All of which had teak decks and lots of teak rails and trim. Then I bought one. Glutton for punishment I guess. :D
  10. CaptEvan
    CaptEvan Senior Member
    Great Lakes
    This is a recipe from a yachting Emeril!
    Savor it, copy it, use it!
    Thanks Capt.Bill
  11. NYCAP123
    That explains the receipe.;)
  12. Capt Bill11
    You're welcome. And pass it on.
  13. sailandfish
    sailandfish Member
    new orleans/ cape coral florida
    The original poster didn't specify so we are all assuming that this is exterior teak, not cabin sole.
    Either way maybe you could post some pics and we could give better advice; otherwise it might just be cheaper/ easier to sub it out. While the contractor does his job watch and learn.
  14. HMI
    HMI New Member
    Tampa Florida
  15. NYCAP123
    Welcome HMI. Beautiful old girl there. Who is she? Lots of varnished wood. Did you get any experience redoing that?
  16. HMI
    HMI New Member
    Tampa Florida
    Thats the "Helene". Berthed in Lake St. Clair, MI. Owned then by old Detroit money. The decks were all teak. Two of us were the "knob polishers". We would start off aft and work our way forward. One to port, one to SB. "Teak" the decks, polish the lacquer and metal. At night she would charter parties. Next AM we were at it again. All summer. Oh and to answer your question. Nope no re-varnishing on that one. Except the decks. We constantly were re-teaking the decks. They supplied the stuff. It was in two parts. A cleaner and a "revitalizer". And we used brass brushes for that if I remember correctly.
  17. NYCAP123
    Old girl; old school.
    That's the brass wool I referred to in post #8, and with all that teaking no personal receipe :rolleyes:
    When my father in law was in the Navy he was charged with polishing the brass. Figuring his time could be better spent he painted it gray.
  18. Captain John
    Captain John Guest
    we thoroughly enjoy the new products at West Marine Ft.Lauderdale called Yacht*****. The Teak Cleaner worked great w/o acids and left our teak decks a natural light blonde color. We then applied the Yacht***** Teak Preserver. This product has no oils. It is water-based and penetrates into the teak. The decks are beautiful still after several months in Florida/Caribbean. Great Stuff!!
  19. NYCAP123
    That's great to hear. I'd not been satisfied with West Marine's Teak Oil and the good stuff like Tip Top is getting hard to find.
  20. Pascal
    HMI
    thank you for posting that picture! what a gorgeous boat!
    on teak deck, I've been happy with the 2 part Snappy New Teak... it restores the natural blond color with minimal effort.
    oil is fine on rails and trim, but not on decks... at least in my opinion. there is nothing like the look of fresh clean blond teak.
    Bill, thks for the receipe, i will try it when i run out of snappy!
