Click for FLIR
Click For Dockwise
Click for Heesen
Click for Sea Spirit
Click for FLIR
Click for Horizon
Go Back   YachtForums.Com > GENERAL YACHTING DISCUSSION > Technical Discussion > Surveying: Thermal Imaging Cameras
Reply
Old 04-27-2009, 09:31 AM   #1
K1W1
Senior Member
K1W1's Avatar
Quote:
This thread is a continuation from another subject, split into a new title -
NYCAP It is easy to do an IR Camera shot of the electrical system with everything running, this will soon show up any hot areas. I can give you a guys No in Ft Lauderdale who works for a large survey company who runs one of these cameras with great success.
__________________
Cheers,
K1W1
K1W1 is online now   Reply With Quote
Old 04-27-2009, 09:44 AM   #2
NYCAP123
Senior Member
NYCAP123's Avatar
Do they do this as a regular part of their surveys or just if requested? I'd never seen it. In fact, we just went through a survey last week. On board was the surveyor, the boat's regular mechanic, a Cat mechanic, the new owner, old owner, the broker and myself. No IR camera.
__________________
"Some went down to the sea in ships."
NYCAP123 is online now   Reply With Quote
Old 04-27-2009, 09:58 AM   #3
K1W1
Senior Member
K1W1's Avatar
Quote:
Might be time to find yourself a new surveyor then.
__________________
Cheers,
K1W1
Old 04-27-2009, 10:22 AM   #4
NYCAP123
Senior Member
NYCAP123's Avatar
Quote:
Today I learned something new (not that it could be done, but that it should be done in the normal course of a survey). Thanks, I'll check into it. I've been dealing with this surveyor for 10 years so I don't think I'll dump him, but I'll certainly ask him about this.
__________________
Old 04-27-2009, 12:35 PM   #5
K1W1
Senior Member
K1W1's Avatar
Not every surveyor will have one as they are pretty pricey but they should all know someone who does and can be used when needed.
We first used them back in 1993 as part of Switchboard Surveys, the images are now accepted by Class.
__________________
Cheers,
K1W1
Old 04-27-2009, 05:58 PM   #6
Opcn
Registered User
Opcn's Avatar
For inquiring minds pretty pricey means 5-10K USD
Opcn is offline   Reply With Quote
Old 04-27-2009, 07:57 PM   #7
YachtForums
Publisher/Admin
YachtForums's Avatar
Quote:
Opcn,
Under the Redenbacher Rule of 2004, you are hereby prohibited from further posting until such time as all parties participating have made some popcorn.
Old 04-28-2009, 04:55 AM   #8
K1W1
Senior Member
K1W1's Avatar
I found a reasonable explanation of the current trend towards using IR Thermal Imaging for Surveys.
Thermal Imaging in Marine Surveying
Suitable Cameras: i5, InfraCAM SD, i50, T200, T250, T360
Once available only to the U.S. Navy, infrared technology now brings state-of-the-art thermal imaging to general marine surveying, so you can quickly and accurately use infrared detection to perform the four "Elements of the Marine Survey"
1. Pre-Purchase Surveys
2. Insurance Surveys
1. Appraisal Inspections
2. Damage Inspections
Thermography is an important addition to the marine surveyor's toolkit, along with the percussion hammer, a moisture metre, and hands-on field experience. With today’s highly sensitive infrared detectors and advanced electronics, you can quickly scan a vessel for structural integrity. You can also examine electrical, propulsion, and fuel systems, as well as navigation and other on-board electronics.
Thermal imaging can detect potential problems that would be invisible, not only to the naked eye but also to many instruments. Electrical, mechanical, propulsion, power generation and other systems often show unusual heat variations before failure. Likewise, structural problems in FRP, wood, and composite laminates are frequently accompanied by abnormal heat signatures. Such problems are clearly visible to the new generation thermal imaging cameras, with their extremely sensitive heat detection capabilities, allowing problems to be detected early and helping to avoid costly and catastrophic failures.
Today’s infrared cameras are lightweight, portable, and extremely easy to use. Often weighing no more than a flashlight, they are highly sophisticated and can store over 100 images on-board, ready to download to a PC at the click of a mouse.
Above info came from: http://www.thermascan.co.uk
__________________
Cheers,
K1W1
Old 04-28-2009, 06:49 AM   #9
NYCAP123
Senior Member
NYCAP123's Avatar
Thanks K1W1. This makes a whole lot of sense.
__________________
Old 04-28-2009, 01:58 PM   #10
YachtForums
Publisher/Admin
This thread has been split and re-titled... "Surveying: Thermal Imaging Cameras".
Good topic. Let's continue...
Old 04-28-2009, 02:04 PM   #11
Marmot
Senior Member
Having used thermography for machinery inspection and troubleshooting onboard ships for quite a few years I have one comment to make regarding use of the technology onboard yachts...
The equipment is now relatively cheap and can be obtained by anyone, the skill required to analyze and interpret the data is not easily obtained and based on what I have read in several yacht surveys, should be subject to considerable skepicism.
Ask a lot of questions about the background and knowledge of the person interpreting the data.
Marmot is online now   Reply With Quote
Old 04-29-2009, 01:42 AM   #12
K1W1
Senior Member
K1W1's Avatar
Quote:
I concur with this statement for sure.
__________________
Cheers,
K1W1
Old 04-29-2009, 02:08 AM   #13
Opcn
Registered User
Opcn's Avatar
If the recent rash of ghost hunting shows in the US, UK, and Australia (sorry, don't know about non-English media) has taught us anything, its that using this sort of equipment is not intuitive and that training and experience are vital to actually making use of them.
Old 04-29-2009, 07:01 PM   #14
Maria B
Registered User
I'll bite....what's the Redenbacher rule? Got to go make the popcorn.
Maria B is offline   Reply With Quote
Reply
Thread Tools
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is Off
HTML code is Off
Forum Jump
All times are EST. The time now is 03:23 PM.
Click for Westport
Click for Dyna
Click for Crescent
Click for Platinum
Click for MCC
