Click for MCC
Click for Cheoy Lee
Click for Westport
Click for MCC
Click for Heesen
Click for Horizon
Go Back   YachtForums.Com > GENERAL YACHTING DISCUSSION > Technical Discussion > Shore water full time hook up - Air Leak?
Reply
Old 04-19-2009, 11:52 AM   #1
jonathanhoskin
Registered User
I own a 1971 Chris Craft Constellation. We've hooked up to City shore water. We have used a RV type pressure restrictor at the inlet. Every time we turn on any faucet there is a vibrating sound of air either escaping or entering (not sure) Is this normal? Its very annoying
jonathanhoskin is offline   Reply With Quote
Old 04-19-2009, 02:54 PM   #2
Capt. Bill11
Senior Member
Capt. Bill11's Avatar
Maybe it's the restricter valve fluttering?
On perhaps you need a pulse damping tank hooked up in your water system if you don't have one already?
Capt. Bill11 is offline   Reply With Quote
Old 04-19-2009, 06:41 PM   #3
corinthian99
Registered User
Is it constant or just as you plug in? If its just as you plug in sounds like the reducer chattering.
corinthian99 is offline   Reply With Quote
Old 04-19-2009, 10:23 PM   #4
Capt J
Senior Member
Quote:
It is normal for some of those regulators to pulse...... remove it from the inlet and hook it up to the city water outlet and the garden hose should take out the pulsing and chattering through the boat. It is also normal to have air if you've turned the hose off and then on again but should only last a minute with a faucet on the boat opened.
Capt J is offline   Reply With Quote
Old 04-20-2009, 10:42 AM   #5
Pascal
Senior Member
Pascal's Avatar
and it's also normal for boat to sink when hooked up to dockside water when a fitting fails... call me paranoid but i never hook up.
and using your on board tank means you are refreshing the contents every few day, keep them fresh and clean.
Pascal is offline   Reply With Quote
Old 04-20-2009, 12:50 PM   #6
NYCAP123
Senior Member
NYCAP123's Avatar
OK Paranoid. One good shower empties the tank...sometimes before you're done. Then there's always tank taste. I'll just shut the water when leaving the boat.
__________________
"Some went down to the sea in ships."
NYCAP123 is online now   Reply With Quote
Old 04-20-2009, 12:52 PM   #7
Pascal
Senior Member
Pascal's Avatar
i rarely wait for the tank to get down to the last shower...
tank taste? nope... good filtration takes care of that along with using the water.
Reply
Thread Tools
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is Off
HTML code is Off
Forum Jump
All times are EST. The time now is 01:43 AM.
Click for FLIR
Click for Crescent
Click for ISA
Click for Queenship
Click for Oceanco
Click for Platinum
