Click For Dockwise
Click For Affinity
Click for MCC
Click for Queenship
Go Back   YachtForums.Com > GENERAL YACHTING DISCUSSION > Technical Discussion > Diesel engine & dinghy
Reply
Old 04-14-2009, 10:05 AM   #16
nas130
Registered User
Weight
Another point being missed is the weight penalty of a diesel, which will require a much stronger davit, which is more weight, etc...
nas
nas130 is offline   Reply With Quote
Old 04-14-2009, 11:06 AM   #17
JWY
Senior Member
The client wants a diesel for the dinghy so as not to have to carry gas or add tankage for gas. There's already a pump w/nozzle installation that feeds from the fuel tanks. He's adding a 3500# davit. The flybridge has had additional support at construction to accommodate the davit weight and stress.
Thanks for any comments.
Judy
JWY is offline   Reply With Quote
Old 04-14-2009, 08:14 PM   #18
Ken Bracewell
Senior Member
Ken Bracewell's Avatar
Judy,
I echo many of the comments here. I've never owned a diesel jet tender but have many friends with them. The larger ones seem to be a little better, but the small ones are a nightmare. I'm a big fan of Nautica and have had many of them. Franco builds a good boat and, more importantly, stands behind his product.
My first advice would be to strongly advise against a diesel tender. While it may be cool to be able to fuel the tender from the main tanks, the hassle associated with small diesels may outweigh the benefits. Perhaps the 3500# davit could be utilized when lifting a gasoline tender with a larger than average fuel tank, therefore minimizing the need to carry extra gas in a storage tank.
If the client is set on a diesel, perhaps an Inboard/Outboard would be a better option than the jet.
Good luck.
__________________
Never trust a captain who enjoys swimming!
Ken Bracewell is online now   Reply With Quote
Old 04-15-2009, 09:18 AM   #19
corinthian99
Registered User
Judy
Think you've hit the nail on the head there. No class issues with gasoline and pratting around with jerry cans.
I've had a dozen + diesel tenders with no problems, can't quite understand some of the posts here talking about diesels not being suitable for tenders. As for Nautica, dodgy quality at best but they are cheap (in every sense).
corinthian99 is offline   Reply With Quote
Old 04-16-2009, 05:26 PM   #20
Capt J
Senior Member
There is no problems having a diesel engine. But you are dealing with a tender that weighs more then equipped with a 4 stroke, aren't gaining anything in fuel economy, and it has less interior room for passangers and provisions which is the primary use of a tender.
I too would only go the stern drive route if possible with a diesel tender. BUT, that makes the tender weigh even more AND makes it longer then a jet equipped one of the same boat length.
Capt J is offline   Reply With Quote
Reply
Thread Tools
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is Off
HTML code is Off
Forum Jump
All times are EST. The time now is 11:14 AM.
Click For Affinity
Click for Christensen
Click for Moonen
Click for ISA
Click for Quantum
Click for Heesen
