Click for Trinity
Click for Ferretti
Click for Llebroc
Click for Cheoy Lee
Click for Dockwise
Click for GPlink
Go Back   YachtForums.Com > GENERAL YACHTING DISCUSSION > Technical Discussion > keel bulb drag
Reply
keel bulb drag
Old 02-12-2009, 07:55 AM   #1 (permalink)
Registered User
keel bulb drag
How much would drag be reduced if you reduce keel bulb volume by 40 % ?
SkipperKnut is offline   Reply With Quote
Old 02-12-2009, 04:29 PM   #2 (permalink)
Senior Member
Marmot's Avatar
Maybe the reason you haven't got an answer is because it is one of those "it all depends" things.
What shape is it? How do you plan to reduce the volume? Are you going to reduce the frontal area? Are you simply scaling down the same shape? Is the bulb a cylinder that you plan to shorten, a foil you plan to alter the aspect ratio?
Make a scale model and drag test it before and after the tweaks is the simple and cheap way to find out.
Marmot is online now   Reply With Quote
Old 02-12-2009, 05:33 PM   #3 (permalink)
AMG
YF Moderator
AMG's Avatar
You are right Marmot, there are too many "it depends". I was thinking of basic things like if the weight is also reduced by 40%, what will happen with waterline length and with healing? Or is it iron being replaced by lead? And naturally, it all depends on the shape, before and after.
Old 02-12-2009, 06:44 PM   #4 (permalink)
Senior Member
Quote:
I thought Naval Engineers designed the keel bulb at a certain size to displace water and not only make the vessel ride better, but to make it more efficient as well? I don't think that making it smaller would increase efficiency, otherwise the naval engineer would've designed it that way in the first place. I may be totally wrong, but doesn't the keel bulb break up the waves so that the vessel maintains a higher average speed in a sea?
Capt J is offline   Reply With Quote
Old 02-12-2009, 07:12 PM   #5 (permalink)
Senior Member
Marmot's Avatar
"I may be totally wrong ..."
Keel bulb:
Bow Bulb:
Old 02-12-2009, 08:40 PM   #6 (permalink)
Senior Member
Ok, got it. But aren't keel bulbs usually found on sailboats and designed to produce as little drag as possible and it allows one to run more sail area in order to increase speed, by reduce keel length while still retaining great counterbalance?
Old 02-12-2009, 09:08 PM   #7 (permalink)
Senior Member
PropBet's Avatar
Quote:
You bring up the critical point here.
Drag in keel bulb is one thing. What the bulb actually does, and modifying that is a whole new scenario. Unless you have the hydrodynamics of a 55 gallon drum as your keel bulb, why and or who are you wanting to reduce its drag by 40%?
Keel length is going to be directly proportional and critical to mast height and sail size / square footage at its greatest efficiency.
PropBet is offline   Reply With Quote
Old 02-18-2009, 12:58 PM   #8 (permalink)
Registered User
Clarification
To clarify - what if a leadbulb was replaced by a gold bulb ? It could be 40 % smaller keeping the same weight and righting moment, but less drag. (It would cost 470 million Euro for an AC boat, so the advantage better be great !)
Old 02-18-2009, 01:14 PM   #9 (permalink)
Senior Member
Marmot's Avatar
" ... gold bulb ..."
Now you are being ridiculous. Everyone knows boatyards are full of crooks, that's why depleted uranium has replaced gold everywhere except the Middle East.
Old 02-18-2009, 02:35 PM   #10 (permalink)
Senior Member
FISHTIGUA's Avatar
Bulls-eye Marmot.
FISHTIGUA is offline   Reply With Quote
Old 02-18-2009, 04:37 PM   #11 (permalink)
Senior Member
NYCAP123's Avatar
Back in the day I saw the lead replaced with cocaine, but never gold. Let me know when you need a diver.
NYCAP123 is online now   Reply With Quote
Old 02-18-2009, 06:52 PM   #12 (permalink)
Senior Member
PropBet's Avatar
Yes.
That should work fine.
We'll obviously need to test.
PM sent with our Captain's name and our dock GPS cord's.
Next Tuesday works for us, if that is OK with you.
K-Thanks.
Reply
Thread Tools
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is Off
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
All times are EST. The time now is 11:59 AM.
Click for DeAngelo
Click for Oceanco
Click for Westport
Click for DeAngelo
Click for Alexseal
Click for McKinna
