| |  | Elevators / Manufactures |  | | |
02-07-2009, 02:36 PM
#1 (permalink)
| | Senior Member
I searched around the forum and find that many of the larger / custom tri deck builders use them, install, or call for them in their plans, however nowhere do they mention manufacture(s) used, types used (mechanical, vacuum, hydraulic, etc).
Has anyone got any information they can share or point me in the direction in which to search?
Much thanks-
~PB
02-07-2009, 02:52 PM
#2 (permalink)
| | Senior Member
02-07-2009, 03:03 PM
#3 (permalink)
| | YF Moderator
And you have these guys: http://www.tbv.eu/ |
02-07-2009, 03:41 PM
#4 (permalink)
| | Senior Member
Thank you Gents-
That gets me pointed in the right direction.
02-07-2009, 06:20 PM
#5 (permalink)
| | Registered User
| Elevators
I've had a couple onboard builds and the best so far has been Lutz. Even then I would recommend seriously considering whether an elevator is actually needed, the space, cost and maintenance requirements are not for everyone. They do need fairly constant nursing by the engineers on board and the stews hate them - all that lovely glass.
02-08-2009, 05:50 AM
#6 (permalink)
| | Publisher/Admin
Elevator have their ups & downs. Yes, they complicate a ship’s systems, but they enable a sector of charter that is otherwise precluded from yacht vacations, or ownership.
… and the padded walls are for pressing the penthouse button offshore.
02-08-2009, 09:59 PM
#7 (permalink)
| | Registered User
| Quote: |
Originally Posted by YachtForums Elevator have their ups & downs. | PLEASE tell me pun intended |
02-09-2009, 01:37 AM
#8 (permalink)
| | Registered User
Join Date: Nov 2008 Location: Monterey, Maui, Salt Lake City
I like the idea of an elevator onboard since I can keep sailing well after four flights of stairs is too much. The same goes for having my soon-to-retire parents on board.
I just assumed that all elevators on superyachts are hydraulic. I can't think of a good reason to install anything else.
My favorite yacht, Latinou, (If only it's price tag was 1/4 less) has 2 elevators aboard. One for guests spanning 5 floors from the sun deck down to the hair salon on the fuel deck. The crew elevator covers 3 floors and goes from the galley, through the crew lounge down to the storage areas on the fuel deck. I'm quite sure both of them are hydraulic.
02-09-2009, 02:30 AM
#9 (permalink)
| | Senior Member
Cables are a popular hoisting method on the superyacht elevators I have been involved with.
02-09-2009, 02:43 AM
#10 (permalink)
| | Registered User
Are most yacht elevators hydraulic?
02-09-2009, 07:15 AM
#11 (permalink)
| | Guest | Quote: |
Originally Posted by PropBet I searched around the forum and find that many of the larger / custom tri deck builders use them, install, or call for them in their plans, however nowhere do they mention manufacture(s) used, types used (mechanical, vacuum, hydraulic, etc).
Much thanks-
~PB | well maybe think of us
02-09-2009, 08:01 AM
#12 (permalink)
| | Guest | Quote: |
Originally Posted by Wanderer Are most yacht elevators hydraulic? | This is always depending on lifting height given space etc.
however i would say that within 15 meters hydraulics is the best.
Traction driven as you see on land a lot you need mores space for the equipment and there is more metallic contact with the ship read noise.
02-09-2009, 08:27 AM
#13 (permalink)
| | Publisher/Admin
Mike,
I have to ask… how hard would it be to pass along helpful information without helping yourself to the opportunity? Since you have taken the liberty to post your URL, your company avatar and your company address in your profile… I have taken the liberty to remove it.
You have been a member of YF for over 1 year. Maybe it is time to read the rules...? http://www.yachtforums.com/forums/ge...uidelines.html |
02-09-2009, 11:18 AM
#14 (permalink)
| | Registered User
Unless an elevator is fast enough it seems to me to be a complete waste of money.
Most everyone I know with a slow elevator in their home uses it more as a dumb waiter than for themselves. (ie. they put the laundry in the elevator and they take the stairs, clean a few more things and then meet the elevator at the top with plenty of time to spare.)
I would assume that in order to get a fast elevator with cables, you would need much larger equipment. Would this be true with hydraulics?
How did Benetti make the elevator on Latinou work? I assumed hydraulics since there is no pulley system above it.
02-09-2009, 12:26 PM
#15 (permalink)
| | Senior Member
It's a Benneti, it might not work and have been in that position for the pic.
Posting Rules
| You may not post new threads You may not post replies You may not post attachments You may not edit your posts HTML code is Off | | | All times are EST. The time now is 04:36 PM. | |
