Click for Nordhavn Click for Abeking Click for Mulder Click for Furuno Click for YF Listing Service
Detroit 149 info request
Discussion in 'Engines' started by mickevans, Jan 9, 2009.
  1. mickevans
    mickevans New Member
    uk
    Urgent Filter inquiry, help please
    The filter I need is approx 2 3/4 ins across and 4ins high. I don't like to dismantle it in case the gasket causes a problem going back on!
    This filter is fitted on top of the engine - there is 1off of these per engine. A small feed pipe from on top of the LHS of the engine filters oil which feeds back to the top of the RHS of the engine.
    (It is not a filter adjacent to the sump - for those I have big Donaldson P55160 canister type spin on filters.)
    The engine is a Detroit 2 stroke diesel Series 149 16cylinder built 1992 approx.
    Model Number 8163-7416
    Type 16V92TA
    Serial number 16VF009473
    The manual doesn't show this filter at all.
    Mick
    I'm not a mechanic, but it sounds like you're talking about a crankcase filter.
  3. Bamboo
    Bamboo Senior Member
    Palm Beach, FL
    You list it as a 16v92, but also call it a 149 - the model # is a 92 series, and may look like or started out looking like this. While I'm not clear as to the specific engine, pre-oiler comes to mind (not filter)- although I could be completely wrong.
  4. Capt Bill11
    Capt Bill11 Senior Member
    Sarasota/Ft. Lauderdale FL
    Can you post a picture of it?
