Click for MCC
Click for Cheoy Lee
Click for Moonen
Click for Sea Spirit
Click for Oceanco
Go Back   YachtForums.Com > GENERAL YACHTING DISCUSSION > Technical Discussion > Changing a ram
Reply
Changing a ram
Old 12-15-2008, 11:56 AM   #1
C4ENG
Senior Member
C4ENG's Avatar
Changing a ram
If you are changing out a ram on a Quantum zero speed stabilizer fin assembly,,,,
Do you think the ram would need to be bleed after installation? If so,, how would you bleed the stabilizers when it is under 2500- 3000psi?
The manuals do not seem to mention the proceedures...
C4ENG is offline   Reply With Quote
Old 12-15-2008, 02:16 PM   #2
K1W1
Senior Member
K1W1's Avatar
You should be able to cycle the fins a few times and get all the air out.
I would advise against playing with the threaded connections whilst they are under working pressure- This is the time they are most liable to fail and wrenching about with them under pressure might encourage a weak or damaged one to let go. ( Murphy's Law)
__________________
Cheers,
K1W1
K1W1 is online now   Reply With Quote
Old 12-17-2008, 07:54 AM   #3
BMcF
Registered User
x2. The actuators bleed out naturally when you cycle them through their stroke range. The only time this is not the case is for the few stabilizer systems out there that are closed-circuit; the Quantum system is not one of those.
BMcF is offline   Reply With Quote
Reply
Thread Tools
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is Off
HTML code is Off
Forum Jump
All times are EST. The time now is 03:52 PM.
Click for Oceanco
Click for MCC
Click for Westport
Click For Affinity
Click for Horizon
Click for Queenship
