Click for Dyna
Click for Heesen
Click for MCC
Click For Affinity
Click for Oceanco
Click for Queenship
Go Back   YachtForums.Com > GENERAL YACHTING DISCUSSION > Technical Discussion > sunseeker manhattan
Reply
sunseeker manhattan
Old 11-30-2008, 11:35 AM   #1
markg
Registered User
sunseeker manhattan
Is there any issue running the heat during the winter months for weeks at a time
I try to maintain 65 f temp.
Is it wearing on the systems
markg is offline   Reply With Quote
Old 11-30-2008, 12:42 PM   #2
Capt J
Senior Member
No, the air conditioners are meant to run in the heat cycle. You might want to even run the heat higher such as 70 degrees. I would doubly make sure the engine room doesn't drop too low in temperature.
Capt J is offline   Reply With Quote
Old 11-30-2008, 12:45 PM   #3
markg
Registered User
you see no issue running 15-20 hours of the day
Old 11-30-2008, 12:49 PM   #4
AMG
YF Moderator
AMG's Avatar
If you have a chilled water system with seawater intakes, just make sure you don´t leave the boat unattended. If a hose bursts you may sink the boat..
(I guess it uses water even in heating mode..?)
Old 11-30-2008, 12:55 PM   #5
Capt J
Senior Member
Quote:
No, it's perfectly normal to run the a/c's for 15-20 hrs a day. It's the same principle it just reverses the freon inside the unit to create heat. Just make sure you clean your sea-strainers once a month, maybe more often. You may want to use some space heaters (the small brick ones with no exposed heating elements) to allow the heaters to cycle a bit more and in case the sea water system gets a blockage you won't lose heat entirely.
Old 11-30-2008, 01:21 PM   #6
K1W1
Senior Member
K1W1's Avatar
Quote:
Originally Posted by AMG
If you have a chilled water system with seawater intakes, just make sure you donīt leave the boat unattended. If a hose bursts you may sink the boat..
Isn't that what the automatic bilge pumps are fitted for?
__________________
Cheers,
K1W1
K1W1 is online now   Reply With Quote
Old 11-30-2008, 02:15 PM   #7
AMG
YF Moderator
AMG's Avatar
Quote:
Aha, I havenīt seen them on crewed yachts. Just alarm systems...
Reply
Thread Tools
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is Off
HTML code is Off
Forum Jump
All times are EST. The time now is 02:39 PM.
Click for Dockwise
Click for Westport
Click for Cheoy Lee
Click for Horizon
Click for Moonen
