Click for Christensen
Click for ISA
Click for Cheoy Lee
Click For Affinity
Click For Dockwise
Click for Queenship
Go Back   YachtForums.Com > GENERAL YACHTING DISCUSSION > Technical Discussion > Auto-pilot question
Reply
Auto-pilot question
Old 11-07-2008, 01:10 PM   #1
Petepd
Registered User
Auto-pilot question
I have a 2005 Sea Ray 390 motor Yacht. I have asked various people this question, and received conflicting responses. When the auto pilot is engaged, is it OK to spin the wheel quickly in order to avoid crab pots and the like? Obviously turning it slowly does nothing, but I find spinning the wheel quickly gets me around the obstacles, then back on course. will this hurt anything?
Thanks in advance for any response.
Petepd is offline   Reply With Quote
Old 11-07-2008, 01:16 PM   #2
K1W1
Senior Member
K1W1's Avatar
If your steering is hydraulic all you are doing is over powering the Autopilot and it then brings you back and settles down. There will be relief valves in the circuit to limit total pressure.
If your steering is totally mechanical ( Chains and or cables) I would say it is only a matter of time till you bust something that is not easy to fix in a hurry as you are careering shoreward.
The above answers are given based on my general knowledge of steering systems but I have no personal experience on the model of boat you mention.
__________________
Cheers,
K1W1
K1W1 is offline   Reply With Quote
Old 11-07-2008, 01:43 PM   #3
Capt J
Senior Member
The steering override is only for emergency purposes. If you use it often, you will destroy your rudder feedback indicator and/or autopilot pump. Both of which are expensive. I'd recommend going to standby or using the dodge/turn button on your autopilot to steer around lobster buoys and such.
Capt J is offline   Reply With Quote
Old 11-09-2008, 09:35 AM   #4
wolfsong
Registered User
any good autopilot should have a emergency over-ride.. at least the ones that i installed have it. if you move your steeringwheel , while in automatic, the pilot should go into standby.
all new pilots installed with axius and zeuss system have this override as well.. you turn your wheel, change throttle position or move your joystick, the autopilot will go in standby..
wolfsong is offline   Reply With Quote
Old 11-17-2008, 08:57 PM   #5
Capt. Bill11
Senior Member
Capt. Bill11's Avatar
Quote:
I don't know, I've been doing that for years and never had a problem with a feedback unit or pump.
I've asked techs about it and none of them has seen a problem with doing it once in a while.
Capt. Bill11 is offline   Reply With Quote
Old 11-17-2008, 09:09 PM   #6
Capt J
Senior Member
Yeah, it's ok to do it once in a while. I wouldn't recommend it on a daily basis or multiple times a day by any means.
Old 11-17-2008, 10:21 PM   #7
Capt. Bill11
Senior Member
Perhaps. But it would be interesting to hear what the manufacturers have to say about it.
Can you say for sure you've seen a pump or feedback unit fail from doing this?
Just curious.
Reply
Thread Tools
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is Off
HTML code is Off
Forum Jump
All times are EST. The time now is 07:54 AM.
Click for Dyna
Click for Westport
Click for Lurssen
Click for Quantum
Click for Platinum
Click for Sea Spirit
