Click for ISA
Click for NorthCoast
Click for Burger
Click for Moonen
Click for Dyna
Click for ISA
Go Back   YachtForums.Com > GENERAL YACHTING DISCUSSION > Technical Discussion > Fuel Efficiency Question
Reply
Old 06-22-2004, 01:36 PM   #1
Capt. G
Registered User
Capt. G's Avatar
Does anyone know if you can gain "mileage" by removing the turbo charger(s) and adjusting the injector pump or replacing the injector tips etc.?
I have a full displacement vessel and do not need the extra power that I have available with the turbo charged Volvo TMD120A engines.
Thanks in advance!
Graham
Capt. G is offline   Reply With Quote
Old 06-23-2004, 02:04 AM   #2
diesel
Registered User
You can turn down your fuel pump to deliver a lower maximum fuel delivery. This will only reduce fuel consumption at or near full load and will lower your maximum RPM under load. Removing the turbo will do nothing. Remember, in a diesel the turbo only pumps in air, not air and fuel. There may be an aneroid on your fuel pump that allows the fuel pump to deliver full fuel once boost has been produced. This essentially reduces black smoke on accelleration. You can disconnect this also which will sort of accoplish what I said in my first sentance. You can disconnect this simply by removing the pressure line from the intake manifold and plugging it. Also keep in mind that any fuel savings from these modifications will be minor and in my opinion, not worth doing.
diesel is offline   Reply With Quote
Old 06-23-2004, 07:49 AM   #3
YachtForums
Publisher/Administrator
YachtForums's Avatar
I knew Diesel would come through with a good answer!
Reply
Thread Tools
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is Off
HTML code is Off
Forum Jump
All times are EST. The time now is 10:05 PM.
Click for Oceanco
Click for Horizon
Click for Queenship
Click for Rybovich
Click for Nautical Structures
Click for Westport
