Click for Delta Click for Cross Click for Perko Click for Burger Click for Mag Bay
Switching to Spin On Filters
Discussion in 'Technical Discussion' started by STICH, Nov 2, 2008.
  1. STICH
    STICH Guest
    I have a 1966 Chris Craft Roamer with twin 671m Detroit Diesals. They have the orig. filters which I an switching to new spin on filters. I know to fill the spin on filters 3/4 full, but does that get rid of enough air that it will not stop fuel flow?
    After you fill them, let the fuel settle in them and refill. The filter will absorb a little over the course of a minute. I would fill them as much as possible. You should be able to start the motors but it might take a few mins to work the air out. Why are you switching to spin on's anyways?
  3. riptidecrew1939
    riptidecrew1939 New Member
    Port Orchard, WA
    Spin-On Filters
    I converted my 671's to spin-on filters about 7 years ago and have never regretted the change. I was having problems getting the "elements" for the old type filter.
    I completely fill my spin-on prior to installing, fill the engine, run it for 10 minutes and check to level again, adding oil as required.
    Works every time.
  4. NYCAP123
    I'm confused. Was this about fuel or oil filters?
  5. K1W1
    I think the first poster was asking about Fuel Filters and the third one was saying about Oil Filters.
  6. NYCAP123
    Thought it was me. For the record: Fill the fuel filters. Leave air/get air lock. No need to fill an oil filter. Put in the right amount of oil. Run the motor. It will circulate through the filter. Then let cool and check level.
    Screw on fuel filters are fine, but I'd prefer them as secondary to a racor which can be checked on a glance.
  7. STICH
    STICH Guest
    Thanks for the advice. My main concern was air in the line after changing for the canister mounts to the spin on mounts. The reason for the change is that the old orig. canister filters are hard to change and take time, and are a mess.
    I never have had a problem with canister filters being a mess. I also have never had a problem for finding the canister filters, even NAPA carry's them.
    Detroit Diesels will usually work the air through the system if they're airlocked, although it does take a while.
  9. K1W1
    NYCAP- Filling up the spin on oil filters is good practice when you can.
    The Lube Oil Pump supplies Oil to the whole engine but the first stop is usually the filter, larger engines have a separate Lube Oil priming pump that either runs pre start up as part of the start sequence ( MTU and newer CAT) or the operator must run it for a while to fill the galleries and filters etc.
  10. NYCAP123
    Thanks K1W1, love to learn. That seems like a messy proposition though. Do they need to be full or just enough to prime?
  11. K1W1
    It's not as bad as you think as long as they are not mounted upside down:) .
    Just stand the filter up in the box it came in or somewhere else it won't fall over and fill it up close to the thread section in the middle, leave it for a minute or so like with the Fuel Filters and then top it off to around the top of the holes in the top plate. You can also dip your finger into the oil in the middle and wipe a bit of it on the rubber gasket set into the top of the Filter itself.
    I have just been reading something where it says that many manufacturers are switching back to Cartridge Type Filters citing the reduction in amounts of waste oil being thrown out with the filter and the ease/costs of recycling Cartridge Filters over Spin On Units.
    So make the most of it these might not be around for ever.
  12. NYCAP123
    Yeah, I was just thinking about those 1 & 5 gal. oil jugs and my friend Murphy (as in his law):D .
  13. Bamboo
    Bamboo Senior Member
    Palm Beach, FL
    DD Fuel filter
    I changed to the spin on in my boat with 16-92's. Everybody has spin-on's, not nearly as many have the old canisters. Fill the filter as much as possible, (make sure to wet the o-ring) get it hand tight, start the engine and run for 10 minutes. I've never had a air lock doing this.
  14. Cthulhu
    Cthulhu New Member
    Charleston,SC
    K1W1
    Would love to know of someone who claims to recycle the oil from old filters. Once I hand it off the to dockhands, I have no idea where the oil or my oily trash goes. One has to hope that the marina has a recycling plan, but I am not aware of it.
    As for the canisters, I had them on fuel & oil for 8V71's. Since the oil filter was mounted upside down 3/4 of an inch above the bilgeplate/stringer, changing them was never easy. The only place I still have canisters is on my reduction gear; if I could change those, I would do it. (There is no documentation for my gears, so I just keep replacing the existing canister elements)
