Click for Nordhavn Click for Burger Click for Westport Click for Ocean Alexander Click for Abeking
Burger 153' Tri-Deck M/Y 2008 - Hull 503C
Discussion in 'Yachts 150' and Up' started by Burger, Mar 10, 2008.
  1. Burger
    Burger New Member
    LOA: 152'09" (46.56m)
    Beam: 29'08" ( 9.04m)
    Draft:Full Load 7'06" (2.29m)
    Gross Tonnage: 499 GT ITC
    Cruise Speed: 13 knots (Approx.)
    Max Speed: 15 knots (Approx.)
    Long Range Cruise:11 knots
    Range: 2,800 NM @13 knots (Approx.)
    Range at LR Cruise: 4,000 NM @ 11 knots (Approx.)
    Fuel Capacity: 17,000 U.S. Gal. (64,350 litres) (Approx.)
    Fresh Water: 3,000 U.S. Gal. (11,350 litres) (Approx.)
    Class: ABS, MCA, A1
    BURGER 503C is actually a four deck motor yacht: cabin deck, main deck, pilothouse/skylounge deck and flybridge deck. All decks are serviced by a full sized, wheel chair accessible, elevator. All five ensuite guest staterooms have king berths. The master is forward on the main deck with two baths and an office. As the layout plans show, there are a dozen or more areas at which to congregate or to be private over 5,000 square feet (466 sq mt) of interior living space and over 4,000 square feet (386 sq mt) of exterior recreation space. The full displacement hull form not only makes all this extra volume available, but importantly gives this yacht the steadiness at sea always desired but rarely found.
    The interior is neo-classical, enriched by traditionally designed, book matched, raised-panel Honduras mahogany and Maple burl joinery which also takes the form of exquisitely curved, molded and radiused detail.
    Years of design, planning and purchasing of exotic materials by an extremely knowledgeable yachtsman have created this exquisite yacht to a degree of elegance far above others. His change of plans makes this masterpiece available. At every turn you will be amazed and pleased by the superb quality of materials and Burger workmanship. That feeling extends also to every fine piece of equipment from night vision camera at the top to the comfort of zero speed stabilizers.
    The top deck is purely for total enjoyment of guests. For the view or for sunning at the Jacuzzi, for chatting at the bar or relaxing in the shaded lounges, or even for driving the yacht from this lofty view.
    The tenders are obscured on the main deck aft where hydraulic bulwarks lower and overhead cranes serenely launch the tenders and toys.
    Please call Burger Yacht Sales at 954-463-1400 for complete details.
