Click for Ocean Alexander Click for Nordhavn Click for Walker Click for Abeking Click for JetForums
Bilge Paint?
Discussion in 'Chris Craft Roamer Yacht' started by milakelovers, Jul 2, 2012.
  1. milakelovers
    milakelovers New Member
    Grand Rapids, MI
    Hi, I just got my first Roamer. It is a 1964, 32 footer. First job will be to clean, scrape and paint the bilge. Glad it is only in the 90s here, otherwise that job might not be so fun :) There is a little bit of surface rust here and there, but it doesn't appear to be too bad. What primer and paint would you recommend?
    What hull material do you have?
  3. Orestes
    Orestes New Member
    RI - Cove Heavan Mariina Barrington
    Orestes
    I had the same issue and I was pressed for time. I had standing water and oil and I could not unplug the bilge plug either, but I had no rust. i scraped the old silver compound , clean, soaped and dried the steel and spread tones of silver Rustoleum to match. Not a problem since.
  4. milakelovers
    Grand Rapids, MI
    Sorry, should have put that in post
    The hull is steel.
  5. doug p
    doug p Member
    PNW
    POR 15 for rust abatement
  6. The_Cap
    The_Cap New Member
    Boat Town U.S.A.
    I know this post is old, but did you buy this boat from Jed? How's it working out for you?
  7. Orestes
    Orestes New Member
    Roamer
    No problem.. my boat came from Port Clinton Ohio, her original name was The Golden Rule. . Working-out OK, striping and upgrading interior, exterior to black/red nothing drastic. I moved the galley up behind the wheel to open the space for an electrical fire place down in the berths, and open a doubler half moon entry to the V berth, the old one looked like the John Locker's box. I also found a parts shop to support the old engines ( 7650 S. Channel Dr. Harsens Island, MI 48028 810-748-3600 Robert Henkel). in case I need to rebuilt one or both.
  8. The_Cap
    The_Cap New Member
    Boat Town U.S.A.
    There's also a great place for Chris Craft parts in Harrison twp. Earl's Marine
  9. Orestes
    Orestes New Member
    great..thanks for the info. O
  10. alloyed2sea
    alloyed2sea Moderator
    Alex, VA
    Earl's a Pearl,...
    ..., but make sure you have ur part numbers ready, he hates rookies.
  11. Ormond Bert54
    Ormond Bert54 Senior Member
    Ormond Beach, FL
    I have been using the POR15 on lots of rusty stuff in my engine room and on my engine. It's a great product.
  12. alloyed2sea
    Alex, VA
    As I live,...
    ...,and breathe: Use Enuff POR 15 and thatz her new name, eh?
    Cheers,
    Eric
