Click for Westport Click for Burger Click for Nordhavn Privacy Matters Click for Walker
37 steel hull roamer
Discussion in 'Chris Craft Roamer Yacht' started by memaw777, Mar 13, 2011.
  1. memaw777
    memaw777 Guest
    I'm looking at 1967 37 foot steel roamer with twin 427s 22+27 props. From what I read I could expect about 1 mile per gallon. I know they say if you have to ask you can't afford it. But is there any senario that you could improve this mileage? Also any suggestions on a surveyor with altrasound.
  2. Fireman431
    Fireman431 Senior Member
    East central Florida
    If you average 1 MPG, about the best you can hope for is 1.5 MPG at just over idle, prob averaging around 6-8 kts (hull speed), but you can do the math to determine the best speed & economy. Installing a FloScan sensor(s) will halp you identify the best cruising speed for your vessel as well as maintaining the total gallons burned.
    http://www.sailingusa.info/cal__hull_speed.htm
  3. Laurence
    Laurence Senior Member
    Chattanooga TN
    2.4 mpg !
    On my 38 Roamer Offshore with Chrysler 413's with 3 blade 22x21 props, I've recorded 1.25 mpg over 32 miles, running on the Tennessee River at 8.2 mph at 1550 rpm. I'm not sure you could pull 1.5 mpg. I have pulled 2.4 mpg on one engine going down river but I don't think that counts.
  4. memaw777
    memaw777 Guest
    thanks guys I have never owned a boat this big and I am just a little nervous. Would it be feasible to put a bow thruster in this boat if I were to buy it? I've been talking to Boat US about insurance any other suggestion would be appreciated. I talked to Davis Surveyors but they do not do ultra sound. Anyone know a good surveyor?
  5. fantasymaker
    fantasymaker New Member
    IL
    Another Downstate ROAMER!
  6. Laurence
    Chattanooga TN
    insurance
    If you ask, BoatUS used to waive ultra sound on steel freshwater boats.
  7. Fireman431
    37' with twin engines? I don't see a need for thrusters, but that could depend on the amount of current you'll be facing in your area. I have a 37' with twins and I never found a need for thrusters. However, I have found plenty of other uses for the $10,000 it will cost to install them.
  8. Laurence
    Chattanooga TN
    Fuel Burn
    Even though this attached schedule is from a 38 CC Commander, I find if very close to my 38 Roamer. I thought it might be helpful for your info.
  9. Fireman431
    Can we still get one for $31,990? I'll take two...:)
