Click for Crescent
Click for Heesen
Click for Sea Spirit
Click for Lurssen
Click for Platinum
Go Back   YachtForums.Com > YACHTS FOR SALE > Sportfish Yachts For Sale > 1985 Bertram 46' - $750K Refit ( Owner Financing )
Reply
Old 07-20-2009, 04:17 PM   #1
CaptMarlin
Registered User
The specifications listed below is a small list of the many upgrades in the refit. I was involved in the refit in 2007 and know this boat well. The cost of the repower was just under the current selling price. The Bertram is turnkey and runs like a top. You will be very impressed with this boat.
$400 K USD
Many Pictures are available.. Interested Parties both brokers and private buyers please send a message
Bertram 46’
A very extensive refit in 2007. Original hull is 1985. Every item on the boat has been replaced with new state of the art equipment. Owners plan was to make the ultimate 46’ Bertram keeping the legendary soft stable ride of an older Bertram no matter what the cost. Owner has spent in excess of $750K in the refit. A very impressive ride with very unique custom styling makes heads turn at any it pulls into. Sought after high performance electronic computer programmable engines make this boat a very economical tournament sportfisher at cruise and at WOT for those Shotgun tournament starts. This is a must see. Owner is offering personal financing for the buyer.
Exterior
Complete Repainting of entire hull with Awlgrip
Sanding of entire hull and house. Exterior barrier coat primary Awlgrip finish. Multiple coats. Mirror finish.
Removal of bow rail
Removal of bow pulpit
Removal of alum. Edging
Removal of alum. Rub Rail
Custom side engine air vents
Replacement with a flush mounted PVC matching color Rub Rail
Removal of windows
Replacement with frameless windows port, stb, and cockpit
Fiberglass Glassing & Reinforcement of the following
All hull side port holes
Bowman Hatches
Front windows
Installation of glassed spray and lift rails
Alum. Custom Fabrication
New alum. Half tower
New Cleats
Custom High Polished
New stainless fuel & water caps
Cockpit
Awl grip paint
New Custom Tackle Center
New Cockpit Freezer
Custom Cockpit Engine Room Access
Custom Live Well
2009 New Cockpit Coaming
LED flush mounted lighting
Bose Surround Speakers
Transom Door
New hardware including all latches and all aluminum and stainless
New alum Ladder
Interior
Master Stateroom
Custom Queen Island Bed
New carpeting with sound shield padding
New interior woodwork
New headliner
Recessed lighting
Custom Mattress
Custom Decor
Guest Stateroom
New headliner
Recessed lighting
Custom Decor
Galley
Custom Corian counter tops
New woodwork
New headliner
New appliances
Teak & Holley floors
Recessed lighting
Salon
New woodwork throughout
Recessed lighting
New Custom Flex Steel Sofa
Helm
New State of the Art Fiberglass Helm. Centerline helm with each angle set at a degree to allow the captain to view most all electronics at a quick glance and eliminating reflection or glare from the sun.
Bluewater Teak Captain & Companion chairs
New Exterior cushions both covering and interior foam
Custom fiberglass hardtop
Flush mounted cockpit flood lights
LED flush mounted white natural lighting
LED flush mounted red night time lighting
Navigation Lights flush mounted Port, STB & Stern
New Isinglass
Electronics
Furuno NAVNET
Redundant electronics 2 of everything
10’ Screens
GPS/Chartplotter, 72 Mile Radar, Sounder
Sirus XM Radio
Simrad Autopilot
Electronic Engine Cluster
Custom “Murphy” Integrated (engines & electronics) onboard computer
Engine Room
Awlgrip painted
Custom Lighting
Custom panels
Engines
Iveco C -13 770 HP 2007 engines 450 hours
Programmable for 825 HP
Performance
Fully loaded with fuel and water
10 knts GPH 10
30 knts GPH 55
2009 Twin Disk Gears & Transmission RATED FOR 900 HP
Mechanical & Electrical
All new wiring including all systems converted to 12 & 24 volt.
NorPro Generator
Running Gear
New Struts
New Dripless shaft seals
New Struts
New Recessed Trim Tabs
Performance balanced 5 bladed props
Fishing Accessories
Unlimited Class Fighting Chair
Triple Spread Outriggers
Center Spreader
New alum. Rocket Launchers and surrounding alum. Railings Live Well Cockpit Freezer
Additional Accessories
Oil less Compressor 150 ft of Scuba hose
Internal High Flow Diesel Transfer pump 30 gallons per minute interconnected to fuel tanks with hideaway flush mounted cockpit fittings
CaptMarlin is offline   Reply With Quote
Old 09-02-2009, 10:11 PM   #2
Grady Smith
Registered User
Bertram 46
Can I get additional pics?
Grady
Grady Smith is offline   Reply With Quote
Reply
Thread Tools
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is Off
HTML code is Off
Forum Jump
All times are EST. The time now is 04:41 PM.
Click for Moonen
Click for Nautical Structures
Click for Quantum
Click for Moonen
Click For Affinity
Click for FLIR
