Click for Moonen
Click for Westport
Click For Dockwise
Click for Crescent
Click for Lurssen
Go Back   YachtForums.Com > YACHT & BOAT FORUMS > SportFish Yachts > Post Yacht > Cockpit Scuppers Rubber Flap Replacement
Reply
Old 04-08-2008, 10:44 PM   #1
mwwhit1
Registered User
I have been looking for years to replace the rubber flaps covering the cockpit transom drains. I think Post used these during the 70's and 80's. I finally found it here: http://www.mcmaster.com/nav/enter.as...2&pagenum=3447
The 12x12" piece works perfectly to make both of them. Part # 8143K14. The white color is actually offwhite and matches the gelcoat well.
Hope this helps anyone looking.
mwwhit1 is offline   Reply With Quote
Old 05-13-2008, 10:59 AM   #2
mwwhit1
Registered User
Don't both with this. After a few weeks in the sun the rubber yellowed heavily. Doesn't match anymore.
Old 05-13-2008, 11:09 AM   #3
NYCAP123
Senior Member
NYCAP123's Avatar
White rubber will always yellow. Have you tried fender cleaner? Whatever you use it will be a forever job though. Do you have a contrasting color on your Post that you could go with like brown or black?
__________________
"Some went down to the sea in ships."
NYCAP123 is offline   Reply With Quote
Reply
Thread Tools
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is Off
HTML code is Off
Forum Jump
All times are EST. The time now is 09:48 PM.
Click for FLIR
Click for Cheoy Lee
Click for Oceanco
Click for Queenship
Click for Dyna
Click for MCC
