Click for Delta Click for Abeking Click for Furuno Click for Westport Click for Northern Lights
What to look for?
Discussion in 'Post Yacht' started by Satterly, Sep 18, 2014.
  1. Satterly
    Satterly New Member
    Deltaville, Va
    This weekend I will be going to sea trial an 84 Post 43'. What would the experienced Post owners be looking for as common known issues on this era of Post Yachts. Thanks for any help.
    -John
  2. P46-Curaçao
    P46-Curaçao Senior Member
    I would look at:
    - Engine temperature during rpm range
    - Maximum engine RPM on both motors
    - Speed during RPM range (app on your cell?)
    - Engine smoke (what color and at what time and rpm)
    - Oil pressure during RPM range
    - How does de gearbox functions (delay? Strange noises?)
    - Gearbox pressure during RPM range
    - Controles working smooth?
    - How’s the steering working?
    - Trim tabs are working?
    - Check for leaks in the engine room, after sea trail (take flashlight with you)
    Keep us posted with your figures and we also like pictures!!
  3. SeaEric
    SeaEric YF Historian
    out on the dock
    Fuel tanks! Make sure that they look good and aren't leaking.
  4. Seahawk202
    Seahawk202 New Member
    Chesapeake Bay
    I would ask how often did he change the oil and filters, and does he have any maintenance records, of work done.
    In addition to everything above, walk the entire boat barefoot, see if there are any soft spots anywhere on the bridge deck, the covering boards, cockpit, and foredeck......
  6. P46-Curaçao
    If you have a survey also, check under floors, look at the toilet system, leaking water tanks and windows!
  7. Satterly
    Satterly New Member
    Deltaville, Va
    Thanks for all the advice. I have already been to the boat and looked at everything easily accessible. Plan to take it out this weekend to see how it runs and if satisfied get a survey done before purchasing.
  8. RT46
    RT46 Senior Member
    P46 is right on the mark.
    I recommend that you do not use a surveyor that is recommended by the owner, broker, or yard. It can be a conflict of interest.
    I have had very good luck using Boat US surveyor referral service.
    Also, it is worth the cost of hiring a separate engine surveyor, a Detroit Diesel Expert.
    Good luck, if you do purchase the Post, I am sure you will not be unhappy.
    I don't know anybody that has a Post that is not happy with the boat.
    My Post has exceeded my expectations of the boat.
  9. Post Mayhem
    Post Mayhem Member
    Deltaville, VA
    Well, the survey has been completed. We got 26.7 knots at @ 2600 RPMs. Both engines ran hot. Came back to normal on reduced power. Wondering if it is heat exchangers or something else. I did not see if the coolant level was checked prior to start up
  10. PtJudeRI
    PtJudeRI Senior Member
    Pt. Judith, RI
    Was the heat read from a pyro meter or the gauge?? I would think the heat exchangers could be a main culprit, but some other factors could contribute.
  11. Satterly
    Satterly New Member
    Deltaville, Va
    Readings came from the gauges. Going to start with the exchangers.
  12. Capt J
    I would check intake water flow first at the seacock or sea strainer, then check raw water impellors/pumos before tearing apart exchangers.....HOWEVER get yourself one of those little camera's and pull a sea-water hose in stick the camera up in there and inspect them before pulling everything apart.....a lot of times it's the first heat exchanger from the raw water pump that catches a bunch of crap in it.
  13. ruby
    ruby Member
    Long Island
    Probably your culprit is the transmission coolers, after that check impellers, then check fuel coolers, then check heat exchangers, then risers
  14. RT46
    RT46 Senior Member
    There are lots or reasons why a boat will run hot, anything from raw water obstructions, raw water or coolant pump, heat exchanger, coolant, over fueling, head gasket, and in a DD you could have heat transfer issues with the liners.
    Also, everything in the E/R could be fine and and the boat could be overloaded with a fouled hull and running gear causing excessive drag and overfueling.
    I attached a picture of a gear cooler from a few years ago.
    This is a picture of the inlet side of the gear cooler from a 46 Post with TIB.
    The picture is of small mussels about 1/4" long obstructing the flow.
    This is what was left after most of them fell out when the hose was removed.
    (btw the engine was not running hot, but I guess it was not running as cool as it could have)
    The Post came from the factory with external Great South Bay type strainers.
    Although I am not sure if necessary, I have added sea strainers as a back up.
  15. Post Mayhem
    Post Mayhem Member
    Deltaville, VA
    Thanks for the info. It's great having a cooperative group of subject matter experts willing to share their knowledge! I hope in the future we will be able to impart some wisdom as well.
  16. RT46
    RT46 Senior Member
    what temps were showing on the gauges?
    I back up the gauges, with regular engine room checks.
    I check the engines with one of those IR temp guns.
    I shoot the both engines on the same spots and note any significant differences.
    I also bought mechanical gauges to place in the engine room and a engine room monitor with a video screen for the bridge. I plan on focusing one camera on the engine room gauges, I just haven't gotten around to that project yet.
  17. Post Mayhem
    Post Mayhem Member
    Deltaville, VA
    Sorry for the long delay in getting back on here. I am going to try the camera to look inside as soon as I get one. I think I know where I can borrow one but might as well have my own. Now I have done something else! I drained the fuel down on stbd eng. blew thru the line and now I am saying to myself "self, that was stupid, now you have to pick up fuel again!" Any suggestions on doing this? I really don't want to put my lips around the hose and pull a suction like I we used to do for gas but if I have to, then I have to.......
  18. P46-Curaçao
    You might have a prime pump!
  19. RT46
    RT46 Senior Member
    most Posts that I have seen have a OEM priming pump with a 3 way switch.
    The pump I have easily fills the racors. (I added dual racors)
    the mechanical lift pump on the engines will usually do the rest.
    I have never had a problem with these engines bleeding air from the lines.
    The priming pump also easily pushes fuel to the generator. I have never had to crack open an injector line to bleed air on the generator either.
    The spin on filters I usually fill with Diesel Kleen,
  20. Post Mayhem
    Post Mayhem Member
    Deltaville, VA
    Not that I have seen. Flex hose to Dahl filter, from there to fuel pump to secondary filter to the head. I have a couple theories that I will try such as use a funnel and fill the line, then fill the filters and use a neat trick the capt in the next slip showed me for filling the fuel rail.
