Click for Nordhavn Click for Burger Click for Ocean Alexander Click for Glendinning Click for Northern Lights
weird noise on 1985 46 post
Discussion in 'Post Yacht' started by ptsbusboy, Aug 19, 2014.
  1. ptsbusboy
    ptsbusboy New Member
    portland, ct
    I have a1985 46 post 6-71 capital gears When in forward gear between 7-13 hundred rpm i can hear a sound like a hollowing. I know its coming from port drive train can hear it on bridge not in bilge. Last night it was pretty loud and then all i did was turn the boat (didnt touch anything else) noise stopped intill i went straight again and noise returned Trans oil full and clean any ideas would be greatly appreciated Thanks Paul
  2. Beau
    Beau Senior Member
    Beaufort, NC
    Hard to say without being on the boat. Usual protocol is to start with the running gear and rudder and chase the sound back to the machinery until you find the source. Hopefully its just a loose prop nut or shaft zinc.... Good luck
  3. ptsbusboy
    portland, ct
    Thanks for the reply and idea's
  4. Marmot
    Was thinking rudder or cross-arm. If not too much work, try adjusting cross-arm to change toe in or toe out to see if rudder bearing wear might be contributing. That will load the bearing a bit and change noise if that is the source.
  5. ptsbusboy
    portland, ct
    Thanks I will check rudders
  6. Beau
    Beau Senior Member
    Beaufort, NC
    Let us know what you find, thanks
    Other options. You might have cable driven tachometers (I've seen them due this when the cable gets old). I have also seen the Glenndenning synchonizer do this. Also Capitals were known to have some whining noise at slow speeds sometimes. Check the prop for a line on it, check the shaft seals and cutlass bearings. But if you only hear it on the bridge, I would look to a cable driven tachometer cable, and the sheathing keeps the noise inside and the noise exits under the tachometer on the bridge. Also check what everyone else has mentioned.
  8. Romashkin
    Romashkin New Member
    Barcelona
    Good day Paul. As I understood, the noise is comong from gear? In this case I'd recommend to check if transmission oil is original one, because it can influence on gear operation. Second thing is that this noise can be due to wearing of friction pairs. In this case you can try to use additives for transmission and noise will decrease after some time.
  9. ruby
    ruby Member
    Long Island
    When you are idling the port side in forward gear, just enough to get the boat to move, then put the boat in neutral as it still moves do you hear the noise. The drive shaft still needs to slightly spin just to see if the noise is coming from inside trans or possibly stuffing box or cutlass bearing. Some times the keyway in the prop may cause the prop to walk slightly as the keyway is worn
  10. ptsbusboy
    portland, ct
    Just a quick follow up after purchasing a mechanics stethoscope I traced the noise that is the loudest just above the port strut so I'm assuming it is the strut bearing will change this winter
  11. Capt Ralph
    You may want to get a diver under there and take a look (feel). If it is a cutlass bearing and it's making noise, It could also be damaging the shaft.
