Click for Mulder Click for Cross Click for Glendinning Click for Westport Click for Nordhavn
Moisture Problem under back saloon window
Discussion in 'Post Yacht' started by kubu, Jun 10, 2014.
  1. kubu
    kubu Member
    Charleston, SC
    I keep having a problem with moisture getting behind the back saloon window. It seems to be coming from the sweating of the inside windows but not 100 %. This will be the second time in about 4 yrs. that I have had to have the problem corrected. Can not find any place that the water is getting under the glass and making it bubble up. My boat is a 1987 46 Post. There is a joint to the port side underneath the window.
    Any help or advise would be greatly appreciated.:confused:
    Thanks,
    Jeff
  2. chesapeake46
    chesapeake46 Senior Member
    Where on the rear window is it failing ?
    meaning the top or outboard side ?
  3. kubu
    kubu Member
    Charleston, SC
    It is right under the large window on the port side. Towards that bottom left corner of the window.
  4. mwwhit1
    mwwhit1 Senior Member
    Jersey City NJ\Boca Raton FL
    There were posts in other topics on this site about the rear bulkhead rotting from water damage. I think it was actually coming from the bridge and through the railing screw holes or other holes up top. Maybe the water is traveling down along the inside of the window and looks to be the glass leaking from outside but actually not. I think you are seeing the damage on the inside since you mention sweating? Peeling\discoloring the inside wood\finish?
    Water leaks are the worst to figure out sometimes.
  5. P46-Curaçao
    P46-Curaçao Senior Member
    I had this when I bought mine, it came from water intrusion for the outside for many years. Water came from the flybridge down thru the ‘ladder opening’.
  6. baltimore bob
    baltimore bob Member
    Baltimore, Maryland
    I expect I will find the exact same condition on mine.
  7. P46-Curaçao
    We renewed the complete interiour...
  8. kubu
    kubu Member
    Charleston, SC
    That is the same place but not near as bad. Where you able to correct the problem?
  9. P46-Curaçao
    Yep, sealed everything properly, and closed the rear of the Flybridge and mounted Cockpit Sunshade, so no water reaches the windows...
  10. kubu
    kubu Member
    Charleston, SC
    Ouch closing the bridge in down in the south would make for a long hot summer.
  11. P46-Curaçao
    Over here, Summer everyday, just close it when you are away from the boat...;-))
