Click for Mulder Click for Delta Click for Glendinning Click for Northern Lights Click for Abeking
Replaced Covering Boards
Discussion in 'Post Yacht' started by kubu, Feb 6, 2014.
  1. kubu
    kubu Member
    Charleston, SC
    Has anyone recently replaced there teak covering boards? Mine clean up pretty good but I like the newer smooth look than the ones that are on my current Post. Wouldbe interested in Costs ??
    If you still have decent depth in the teak, you can sand them and they will be smooth again. If not you'll need to replace them. They're not cheap by any means, but I don't know the pricing.
  3. P46-Curaçao
    P46-Curaçao Senior Member
  4. Seahawk202
    Seahawk202 New Member
    Chesapeake Bay
    I had mine replaced last spring. I saved a lot of money by using two boards instead of one wide piece, it looks like it did from the factory. A 12" wide piece of teak is running about $35 a board ft. the cost was $4,700.00
  5. P46-Curaçao
    Seahawk202, Could you post some pictures?
  6. Seahawk202
    Chesapeake Bay
    I will do that the next time I go down to check on my ice eater
  7. Bill106
    Bill106 Senior Member
    Beaufort NC
    Be thankful it was only 12" wide! Last set of 18" 5/4 bookmatched boards I bought cost $55/bd.ft. and a 28" wide one for the transom/fish box was $57!
    Also beware the raw cost of the new teak itself is many times not the biggest expense. I'd say about 50% of the covering boards I've replaced had more serious underlying issues with the substrate they are mounted on that was difficult to detect before removal. If there is wood beneath and screws were used to fasten it down there may be water damage requiring more intensive care.
