Click for Delta Click for Abeking Click for Cross Click for Mag Bay Click for Ocean Alexander
80's POST Bow Railing Pulpit Piece Needed
Discussion in 'Post Yacht' started by mwwhit1, Dec 3, 2013.
  1. mwwhit1
    mwwhit1 Senior Member
    Jersey City NJ\Boca Raton FL
    Does anyone know of a stainless bow railing removed and sitting somewhere? Since I bought the boat the railing at the tip of the pulpit has been bent. I'm looking for this front piece that joins into the rest of the railing and the 4 vertical stanchions on the pulpit. I'm pretty sure the pulpit\rail is the same on the 42 - 46 models for this front section.
    Figure this is easier than trying to have it straightened or replaced if one is laying around.
    Thanks, Mark.
  2. RER
    RER Senior Member
    Newport Beach CA
    It probably isn't. The damage as you describe would be much simpler to have repaired vs buying and replacing the entire bow rail.
  3. mwwhit1
    Not looking to replace\ship the whole rail. It is three pieces with the pulpit part bolted to each side. Only want the rail going around the pulpit which is around 4'x5' in size.
  4. RER
    RER Senior Member
    Newport Beach CA
    Well, if anyone has a Post bow rail laying around and they're willing to sell you part of it you'll be good to go.
  5. Beau
    Beau Senior Member
    Beaufort, NC
    Mmwhit
    Is your rail original, I thought they were all one piece rails?
  6. mwwhit1
    It certainly looks to be original. My guess is if the boat came with a pulpit (maybe an option?) then the rail around the pulpit was spliced\bolted into the sides. I'll have to take a pic when I am back at the boat. It has a smaller piece of tubing inside the joint that has bolts through each side to hold it together.
  7. Beau
    Beau Senior Member
    Beaufort, NC
    Maybe someone like RT46 can confirm that his is pieced also?
  8. P46-Curaçao
    P46-Curaçao Senior Member
    Old picture, but gives you an idea
  9. Beau
    Beau Senior Member
    Beaufort, NC
    Thanks P46. Decide on a watermaker yet?
  10. P46-Curaçao
    Hi BEAU, I think about the Katadyn 40 or 80 model, but a friend of mine knows a boat owner that has a (almost) new one in his garage...so wait to see what he's got and then decide, I would like to make one myself, but have so much boat work to do...it would be wiser to buy one!
  11. mwwhit1
    Perfect Pic. Thanks!
  12. P46-Curaçao
    Even a better (old) picture, it shows it's a separate piece
  13. ruby
    ruby Member
    Long Island
    I have the same bow rail on my 1986 46 Post, I am sure that any canvas guy who bends stainless steel can remake the top part of your pulpit bow rail. The lower vertical stanchions are die-pressed and would be difficult to create.
  14. RT46
    RT46 Senior Member
    I have the same bow rail on my 46 Post
