Click for Burger Click for Mulder Click for Delta Click for Furuno Click for Nordhavn
Winterizing MAN's on 2003 56 Post
Discussion in 'Post Yacht' started by ESSRTEE8, Oct 28, 2013.
  1. ESSRTEE8
    ESSRTEE8 Member
    56 POST in Monmouth Beach NJ
    New to me 2003 Post 56 with D2842LE404 1300hp motors.
    I need to winterize soon. On my last boat I would take to intake water hose off seacock and put in bucket. This boat has 3" hoses and without breaking them free from the seacock fitting to do the bucket method I had a thought.
    On the seawater pump and the hard pipe coming off the pump, there are brass plugs. Is it possible for me to shut the seacock and us a pump to push the pink thru either of these ports and thru the motors. The water discharge hose coming off the motor going the exhaust is positioned low enough so that water will not go back into the motor via the exhaust pipes. Not sure what type and size of the thread. Looks metric and fine thread too.
    I was hoping to not have to disturb the hoses coming off the seacock as this can be a challenge to get them off. The only other thought was to use the crash pumps. I can plug the limber holes and file the section between the stringers with pink and have the crash pumps do there thing.
    Thoughts on my ideas?
    crash pumps are easy, just put a bucket in there and pour more as needed.....or we just do it through the sea-strainers, take the lid off, have a big jug above it with a hose (with a valve) running into the open sea-strainer and run the motor and add at the same time.
  3. ESSRTEE8
    ESSRTEE8 Member
    Not strainers in the engine room. South bay strainers on the bottom.
    The way the crash pumps is setup, I can get a large enough container in there. Maybe a 1 gallon container. I might have to rig up a 5 gallon pail to feed into the 1 gallon.
    I was hoping the just pump it through. Might hav to get creative with the crash pump.
  4. Sea Gull
    Sea Gull Member
    CT
  5. mwwhit1
    mwwhit1 Senior Member
    Jersey City NJ\Boca Raton FL
    Found this pic online of another 56. Should be your setup?
    Short term - this may sound a bit crazy but what about a heavy duty garbage\leaf bag. Fill it with the 4-5 gallons and let it draw from that to keep everything clean. Maybe a small strainer of some sort in the bag around the pickup to keep the bag from blocking?
    Long term, what about replacing the 90 elbow with a 3 way bronze valve? Then you can screw a host barb into the other opening and just divert to which pickup. Hard part may be finding the size since it looks like 2" or more. But this would make future years super easy.
  6. Beau
    Beau Senior Member
    Beaufort, NC
    Odd that Post never installed strainers. I do my 820's like this. I have jigged up a cap from plumbing fittings that goes into the end of the seawater outlet running into the muffler (inch and quarter?). I then open the bleed screw on top of the water pump, careful to catch/redirect the saltwater that flows out, and the bleed screw at the bottom of the thru hull fitting (after I close the valve.) I then pump the pink thru the discharge hose until it comes out the pump and the thru hull. Sounds complicated, but easy once you've jigged up a hose fitting.
  7. Ormond Bert54
    Ormond Bert54 Senior Member
    Ormond Beach, FL
    Have you shown us other photos of that boat? Sounds nice. 1300hp ... she goes too!
  8. ESSRTEE8
    ESSRTEE8 Member
    That pic shows how my setup is exactly.
    Hose and pipes are 3". Big.
    The soft bucket might work or a small garbage can that I can feed with a 5 gallon pail with fitting on the side. I wish they would give better options to winterize when they build them. I hate to try and dis assemble the plumbing. Not much room and after 10 years it won't come apart without a fight.
    Beau, The hose going into the exhaust pipe is in a tough place to get to. Plus it's 3" hose which is big and hard to remove, again, without a fight.
    Pumping forward thru the bleed screw was my first thought about doing it. Do you think it could be done if I pump thru the 2 bleed screws?
  9. ESSRTEE8
    ESSRTEE8 Member
    At her home dock.
  10. ESSRTEE8
    ESSRTEE8 Member
    I think this is the only active forum on this whole site.
    Keep it up guys.
  11. K1W1
    What exactly does that comment mean?
    There are many other postings elsewhere on here in many threads , just not in the thread on this particular brand of yacht.
  12. weto
    weto Senior Member
    NOR CAL
    Nice boat, ODD comment !:confused:
  13. ESSRTEE8
    ESSRTEE8 Member
    You guys go on any other boating forums?
  14. chesapeake46
    chesapeake46 Senior Member
    ARE there other boating forums ? :confused:
  15. ESSRTEE8
    ESSRTEE8 Member
    I don't think so.
  16. captaintilt
    captaintilt Senior Member
    Great Lakes / Florida
    Wow, she's gorgeous.
    I'm going to be the first to say, that I typically like to see OR's on a Sportfish, but she looks great without them as well. Beautiful!!!
  17. ESSRTEE8
    ESSRTEE8 Member
    I think you're right, I like it without the riggers.
  18. captaintilt
    Some Sportfish look completely "out of sync" without a Tower or OR's, but the proportions and lines of yours are "spot on". The last Post that I saw was a mid-90's and much smaller, so to see a 2003 look that good is a nice treat!
  19. RT46
    RT46 Senior Member
    I installed strainers on my 46 Post
  20. ESSRTEE8
    ESSRTEE8 Member
    I wish I could, bt 3" strainers are big as well. Don't have the space.
