Click for Delta Click for JetForums Click for Ocean Alexander Click for Mulder Click for Mulder
brows debrowing
Discussion in 'Post Yacht' started by RT46, Oct 14, 2013.
  1. RT46
    RT46 Senior Member
    Has anybody removed the teak brows from their older Post?
  2. P46-Curaçao
    P46-Curaçao Senior Member
    I removed the one on the front window
  3. P46-Curaçao
    Much better now
  4. RT46
    RT46 Senior Member
    I agree it looks much better.
    what was involved in removing the brows?
    are they just screwed in?
    is there some kind of adhesive?
    was there a color difference in the gelcoat?
  5. P46-Curaçao
    Yes, just screwed in, I found no adhesive, just some sealer, took me half an hour to remove, but be prepared to re spray the whole section.
  6. RT46
    RT46 Senior Member
    I am considering de-browing the Post.
    My salon windows DO NOT leak.
    Does anybody have any thoughts of the function of the brows in deflecting rain water from the windows?
    Has anybody experienced salon window leaks after de-browing?
    thanks
    RT46
  7. P46-Curaçao
    I found no problems at all, I think they are/where there for aesthetic reasons only!
  8. Beau
    Beau Senior Member
    Beaufort, NC
    RT
    Had teak brows on our Egg Harbor and they served no purpose that I could discover except the look - and the work they created. In the later Post models they became an option. Less and less purchasers selected the option from what I can tell being on the water with them.
  9. ruby
    ruby Member
    Long Island
    Lou, I had removed the wood in the front and around the salon windows, and also the chrome grab handles.
  10. RT46
    RT46 Senior Member
    Ruby,
    did you have discoloration of the gelcoat under the wood?
    If so, what did you paint it with?
    also how to you make it up the on the bow without those grab rails?
  11. P46-Curaçao
    I like the much cleaner look Ruby!
  12. ruby
    ruby Member
    Long Island
    Lou, discoloration isn't the problem when removing the teak. You need to close the screw holes and paint the area. I didn't notice any problems walking without having those front grab handles. And yes I agree also that the no teak up front and on the sides look cleaner.
  13. Beau
    Beau Senior Member
    Beaufort, NC
    Ruby, do you have the hand rail that goes over the side windows? Don't remember
  14. mwwhit1
    mwwhit1 Senior Member
    Jersey City NJ\Boca Raton FL
    Ruby, did you replace your bow railing mounts? They look shiny. The chrome has long gone on mine and hoping to find stainless ones that fit the exact same screw holes.
  15. P46-Curaçao
    Same here, I will renew them in time also, so if you find the right ones at the right price, just let me know!
  16. ruby
    ruby Member
    Long Island
    Beau, I do have the original side hand rails. Enclosed is a pic with the beautiful Bodacious in the background. MW Whit 1 I did replace all 22 bases with stainless steel versions. They covered all unused holes, note some holes did need to be re-drilled. The original holes were drilled slightly bigger and filled with West system 6-10, then I used 5200 to bed the new bases. Just an FYI for you guys who need to replace their bases, they are not through bolted at least on my 1986 46, I do hope you will find the same on your own boats, which makes the job much easier. The end cap which is located midship on port and starboard sides is basically a fitting that is used in canvas shops when they make top frames. I will report back with the angle degree of the bases, I think I may have saved the package so to help identify what I had used, if my memory serves me correctly there may have been a few that were a different angle.
  17. P46-Curaçao
    That would be great Ruby!!
    Your Post is the one on the left side?
  18. ruby
    ruby Member
    Long Island
    P46, yes mine is on the left side, the one on the right is Beau's 50'
  19. P46-Curaçao
    Wow, she looks bright and shiny, have you repainted her?
  20. ruby
    ruby Member
    Long Island
    I did repaint from the flybridge down to where the non-skid is on the gunnels and to the bottom of the front seat/ledge. Nothing like Imron, the color formula was dead on with the factory color. I did a few real small touch ups on the sides below the rub rail. The entire hull was sanded and buffed
