Click for YF Listing Service Click for Walker Click for Westport Click for Nordhavn Click for Burger
Post 43 Cruise Speed?
Discussion in 'Post Yacht' started by Gray-Sea, Sep 7, 2013.
  1. Gray-Sea
    Gray-Sea Member
    Virginia Beach
    Going into a survey, what ballpark cruise should I reasonably expect from a 1986 Post 43 with 671s at 450hp each? The broker's info claims 21 knots at 2,050 RPM, WOT 27 knots, unknown RPM.
    Thanks for any information!
  2. RT46
    RT46 Senior Member
    I bet those numbers are pretty close, maybe a slight bit high, but on or close....
  3. Capt Ralph
    The 450/485 hp 671 spins max at 2500 rpm. 80% or 2000 rpm would be ideal cruise if the bow stays down at that speed.
    I recommend not cruising past 2200. Somewhere in between 2000 to 2200 you should find a nice ride 14 to 18 gph, each..
    Max cruise rpm at 2250 or 90% throttle pushes the duty cycle pretty hard..
  4. RT46
    RT46 Senior Member
    Agree with Rcrapps....
  5. mwwhit1
    mwwhit1 Senior Member
    Jersey City NJ\Boca Raton FL
    Here is what I get with my 84 43 with the same HP: 2000 = 20-21, 2100 = 22-23, 2500 = 27-28 knots. Obvious things like how much weight has been added, condition of bottom and running gear, tuna tower will all work to slow it down.
    Just for reference, I'm running 3 blade Nibral 24x25 cupped props.
    Good luck with the Survey.
  6. Berean
    Berean Senior Member
    Sarasota FL
    How was the survey? Did you ever get the Post?
  7. Gray-Sea
    Gray-Sea Member
    Virginia Beach
    The boat went into foreclosure before we could move ahead with a survey so we backed out. Still on the hunt for our next boat!
  8. Berean
    Sarasota FL
    Gotcha. Too bad. We are looking too...
  9. mwwhit1
    Both of you looking for a 43 specifically?
  10. Berean
    Sarasota FL
    I am. Just looked at one here in FL. I want to make an offer but I'm hoping my boat sells first. Quickly. I don't want to be a two boat owner but I hope mine sells before the Post does:)
  11. Capt J
    Price moves everything!
  12. Berean
    Sarasota FL
    Yes it does. I just dropped my price significantly. Starting to get interest, so hopefully I'm on the right track...
  13. Capt Ralph
    Ya know what bank? Banks broker? Could be a new deal if you can stay in touch with the note holder.
    Sadly, repossessed boats have been popping up a lil more often. Of courses the lending institution still does not want to give anything away, but if she was in decent shape, could withstand some rough storage, could still be a bargain for those with patience and cash.
    Good luck
    ,rc
  14. ruby
    ruby Member
    Long Island
    I am thinking about the possibility of moving up to a 50, so if you are looking for a mint 1986- 46 let me know. There are pics of my boat on the forum
  15. RT46
    RT46 Senior Member
    Ruby,
    I agree, then only thing I don't like about my 46 Post is that it is not a 50 Post.
    My next boat will be a 50 Post.
    Regards,
    RT 46
  16. Berean
    Sarasota FL
    Finally!
    I put a contract on a 1984 43 Post with DD 6-71TIs (450s).
    Survey next week.
    I am stoked!:)
  17. RT46
    RT46 Senior Member
    Brenan,
    good luck with the survey.
    let us know if you have any questions or concerns.
    There are lots of knowledgeable Post owners on this board.
    regards,
    RT
  18. Capt Ralph
    Post kids are great..
    71s Rule..
    ,rc
  19. Berean
    Sarasota FL
    I know this is OT but do you guys know how many Post 43s were built? They seem to be far less common than the 42. Looking at this particular forum I think I would be lucky to find even a handful of 43 owners. Just curious...
  20. RT46
    RT46 Senior Member
    I am not sure how many 43s were made, but the 43 is considered an improvement from the early 42s.
    I think that the 44 was the smallest production run that came after the 43.
    The early 42s should not be confused with the later 42s.
    The later 42s had the all the improvements of the 43s.
