Click for Abeking Click for Abeking Click for Walker Click for Burger Click for Westport
what does my hull number reflect?
Discussion in 'Post Yacht' started by about time, May 6, 2010.
  1. about time
    about time Member
    ponce inlet fl
    I have a 1980 46' post sportfisherman. It has hull # 023 stamped in numerous places. Does anybody know what that means? I know post started in 1957, mine is a 1980, 23 yrs, hul #023???? Maybe 23rd 46' boat produced??? Maybe 23rd boat of that year??? How many boats did post build a year? Were they considered "custom", before becoming a "production' boat company in 1988? There is no HIN number stamped on the stern. I was told that this is typical for this time period???
  2. SeaEric
    SeaEric YF Historian
    out on the dock
    Every boat built since 1972 should have a 12 digit HIN.
  3. about time
    about time Member
    ponce inlet fl
    where might the hin be located
    Is there a standard in the industry besides on the starboard side transom? I have seen other boats without a HIN # visable on the stern. Any suggestions on where else to look?
  4. SeaEric
    out on the dock
    On my 1981 Post 42, I think the HIN was in the center of the transom just below the rub rail. As I recall, it was hard to read. It could also be on the lower stbd transom corner just above the boot stripe.
    Has your hull been painted? Sometimes the HIN disappears during a paint job.
  5. about time
    about time Member
    ponce inlet fl
    I will look closer at the transom area. Thank you for your reply. Any inclination on what the hull number might reflect? What was the hull # of your 1981 42'?
  6. SeaEric
    out on the dock
    My 42 had HIN# PMC42194M81H. She was Post hull # 194 which you can see in the HIN. I had always assumed that she was hull 194 of the 42's.
  7. Beau
    Beau Senior Member
    Beaufort, NC
    About Time
    Aside from the HIN. Post refers to its boats for their own use by size and hull count. for instance when I request info, I tell them my hull is 50-042. which to them means its 50 feet and was the 42nd hull of that length manufactured. I would guess your number with Post is 46-023.
    I believe Post keeps info on every boat it manufactured by using this system
  8. chesapeake46
    chesapeake46 Senior Member
    Possibly your hull maybe had blisters, was shaved and repaired and never got the nubers re-engraved into the new repair ?
    I know of one other boat with that scenario.
  9. mwwhit1
    mwwhit1 Senior Member
    a
    Yes, you have the 23rd 46 they built. This timeline: http://www.postyachts.com/a_pgs/pgs_prd.htm may help you. Your boat is 2-3 years into the 46 run.
    Almost every Post I have looked at in the water (being nosy) has the plate on the starboard transom just below the rub rail.
    Your HIN should be like SeaEric referred to: PMC46023?80? Another 1980 46 HIN will probably have the same letters as yours to fill in the question marks.
    Is your boat documented? HIN has to be on that blue certificate you receive each year.
  10. SeaEric
    out on the dock
    Nope. I looked on the net. His CG Doc says Hull # is 46-023.
  11. about time
    about time Member
    ponce inlet fl
    yes my documentation says 46-023. Is that wrong? Do you suggest I get that fixed? I still can not find a HIN on the transom. I know the hull has been treated with Interlux interprotect but it has never been painted above the water line. Does anybody know approx. how many boats post built a year? Thank you all so much for the great info so far.
  12. chesapeake46
    Mine hull # is at the water line beneath the boot stripe.
    Mine is # 21 built in 1980.
  13. about time
    about time Member
    ponce inlet fl
    Thank you Chesapeake46 I found mine on the starboard side right at the bottom of the bootstripe. Our hull numbers are #21 and #23 of 1980. I would assume we have the same power (6-71 J&T turbocharged?) I purchased my Post after she burned pretty bad. For 2 years now I have rebuilt her, almost done. I have yet to run her and was wondering what speeds and fuel burn to expect. I am told 20-21 knts on the pegs and maybe 17-18 cruise. Burning around 30gal/hr. @ cruise. My research has shown a wieght of apporx. 48,000 lbs, and drawing 3.5 '. How do these figures compare to your experience?
  14. chesapeake46
    Congratulations on fooling yourself into believing you will EVER really be done ! ;)
    I have 410 Hp, 671's with turbos.
    They are rated at 2650 rpm no load and 2550 at full load.
    I run mine at 2250.
    Depending on the wind and the tides and the sun and the moon, I run at anywhere between 20 and 22 knots@2250.
    At 2100 rpm I run around 19, 20 knots
    I burn about 25 gals per hour consistantly.
    My starboard tank always takes about 20 gallons more than my port tank which I attribute to the genny.
    I generally do not let the tanks get less than 1/2 full and more than likely top off after any long distance travel because I like the boat heavey in case of rough seas. This is my own opinion.
    I run the genny whenever I run the boat to keep it limber. ( 7.5 Kw Onan )
    At 17 knots and below the boat does not respond well.
    It is on plane but seems almost in transition, it wallows in a sea.
    3.5 feet draft is the same as mine.
    48000 Lbs is what I always quoted lift operators but I do not think it ever tipped the scales on those same lifts at that much.
    I never wrote it down but I think the most she ever weighed on a lift was 42000 lbs. that was full of fuel but no water at all.
    I only have 80 gallons water storage after removeing the original tanks that had split and replacing them with bladder type tanks.
    This is adequate for my use around the bay.
    Also mine is the galley down model which has a rinky dinky sized dinnette and long isle style galley.
    The salon is pretty big and comfortable.
    This boat layout is perfect for two of us.
    I wish you the best with you Post.
    I have enjoyed the heck outta mine.
    Where will you keep the boat ?
  15. chesapeake46
    About Time, a question for you....
    why did the boat burn ?
    I had an aquaintance that had a 46, (1979 I think ) that also burned.
    It did not realy burn so much as get completely full of soot.
    This was attributed to the trubo falling off of the exhaust manifold due to loose clamps.
    The hot exhaust gas melted the cabling into a giant molten mass that would not budge.
    The engine was trying to run at 2000 + rpm but with no turbo boost, it was a giant carbon pump.
    The skipper could not move the emergency kill cables from on the bridge.
    When he opened the hatch in the salon the back smoke ( soot ) poured in the boat.
    Also the Port engine and genny were now breathing in sooty air.
    He could not get to the fuel solenoids to manually shut the boat down and in the end he had ( I think it was his kid ) crawl up from the rear hatches to shut down the fuel valve to the motor.
    A real mess and a real miricle thet saved the boat and people on board.
    He did go on to rebuild the boat better than when he got it.
    As I recall it was black and purple inside if anyone has seen it.
    The skipper sold the boat I think a few years ago.
    I cannot for the life of me remember the name of that boat but we ended up calling it " Velvet Elvis " because of the black and purple interior........
    PS. I check those same clamps annually.
  16. about time
    about time Member
    ponce inlet fl
    That info is great, thank you. My fuel tanks are laid out forward and aft, not side by side. I have replumbed, and replaced the tanks so both motors and the genset can be run off either tank (including returns). When I said I was close to being done, I should have said close to being at the point where I can run her. 25 gals for the genset? That seems like alot. I was under the impression the genset should only burn 1-2 gals per hour ( 7.5 KW).
    Do the engines seem happy @ 2250, that sounds like alot. I would be very happy to criuse @ 20 knts.
    I also have the galley down, I just got done installing a larger 21 cu ft samsung refrige, side by side with a draw freezer on the bottom.
    The steps are a little steep, but other than that its OK. My youngest son graduates college in two years, would like to live on her for 5-10 years.
    The boat burned from an electrical short on the port side aft salon, where the wires run up to the helm. Minimal engine damadge, but extensive smook damadge to the interior. The fire actually burned through the house, and part of the hull. Extensive fiberglass repair, including molding a new engine room intake. All wiring in the salon up to the helm has been replaced.
    The boat is docked in Ponce Inlet FL. I have a marine repair bussines there, I am a marine mechanic/ surveyor/ electrition.
    Your friend had to crawl up from the rear hatches? Do you mean the fish boxes in the cockpit? The only access I have is in the salon. After moving some furniture I have great access. I cant imagine crawling in from the cockpit.
    By the way the halon system never went off in the engine room, it should have though there was alot of heat down there.
    Yea if that turbo burnt the wiring at the rear of the engine, the fuel shut offs would probably not work.
    When the fire dept. got to my boat the engines where running, I heard that is not unusual, afterall just melt the starter wire to a hot wire and the engines will start, and run. I had to replace all of the control cables, including the emergency shut down. In fact I make it a habit to keep the flapper in the off position, just so the shut down cables get used on a regular basis.
    How concerned are you of a "runaway" with these two strokes?
    Do you stow a dingy with a davit on the fordeck? I heard this will effect the following sea problem with this hull.
  17. about time
    about time Member
    ponce inlet fl
    The boats original name was "JUST CRUISING", her home port was in Maryland. I think it was for tax reasons?
  18. chesapeake46
    Could be the starboard engine uses a little more fuel than the Port.
    That is not to say 20 gallons an hr but 20 gallons more on a fill up of ,say, 200 gallons......
    I never gave it much thought and only picked it up because I keep track of all my fuel and realized the trend.
    I was just happy that 25 gallons an hour seemed pretty good for a 44000 lb boat at around 20 knots.
    I should note that I have a rag top not a hard top which would prolly slow you down a knot or two........
    I would like a hard top but I don't want to give up even 1/2 knot of speed !!!:eek:
    They seem to be fine at 2250. Some people look at me funny and think thats too hard on them.
    My understanding of 2 strokes is that they were not great over the road type engines as they were put through the gears and constant RPM changes, but, they were excellent for generators, pumps and boats as they were run up to an RPM and kept there for a long period.
    I have run mine for about 17 yrs at 2250 and do have not had any problems other than regular maintanence. ( having said that I will light a candle for the DD gods...... )
    They are just now beginning to smoke when they are cold.
    this clears when they warm up.
    They both start well and s do not need a sniff to run even in the cold weather.
    They have around 3600 hrs on them
    That is a great idea.
    I replaced mine a couple years ago with an apartment size fridge.
    I believe the fuel valve is reachable from the fish box access in the deck.
    They said after he tried to get in through the salon hatch he was choking and completely covered in soot. I believe his son pulled the rear hatch and turned the valve off.
    I have not heard of any run away engines in the recent past.
    It is a concern but my air cut offs on the blower box work.
    If you kill the air the engine cannot run.
    I have an 85 lb inflatable on the bow.
    It does not affect the attitude of the boat at all.
    I think when you put a small whaler on a 42 the real problems start.
    I really hate the look of the inflatable but it is so handy that I felt the trade off was necessary. We use the heck out of it at anchor or in some ports of call.
    The name is not familiar to me.
    Maryland has had a 5 % tax since I was a kid.
    Delaware is the favorite game here. De has no sales tax. Folks buy a boat and register in De but keep it in MD.
    Usually upper end of the bay.
    Every Spring the MD federallies ( Sate-a-rallies ? :confused: ) make the rounds to the marinas looking for DE registrations so they can get their fair share !!
  19. about time
    about time Member
    ponce inlet fl
    17 yrs with the same boat, WOW sounds like a satisfied customer to me.
    Any problems with the bottom? blisters, stress points, corrosion around through hulls?
    Would love to do the "great loop", are we to tall???
    Just purchased a used hard top from surplus marine in Ft. Pierce. $800.00, plan on installing next month. I will have a little leaway in the final hieght, if I am close. Just starting to research the loop.
  20. NYCAP123
    Been checking myself. About to do a run from Detroit to LI. Here some info that will help. You may have to do the Welland & Oswego Canals. (remember to bring a passport for Canadian Customs since last June).Total Mileage: 524 miles
    Segment Mileage:
    Erie Canal: 338 miles
    Champlain Canal: 60 miles
    Oswego Canal: 24 miles
    Cayuga-Seneca Canal: 12 miles
    to Ithaca and 45 miles
    to Watkins Glen/Montour Falls 45 miles
    Lock Dimensions
    328 feet long, 45 feet wide
    Area available for vessels: 300 feet long, 43.5 feet wide
    Information on How to "Lock Through" Canal System Locks
    Bridge Clearances & Channel Depths
    Bridge Clearances Channel Depths*
    Erie Canal
    Waterford to Three Rivers 21 feet 14 feet
    Three Rivers to Tonawanda 15.5 feet 12 feet
    Oswego Canal 21 feet 14 feet
    Champlain Canal 17 feet 12 feet
    Cayuga-Seneca Canal 16.5 feet 12 feet
    *Bridge clearances are given at normal pool and are subject to variation.
    Here's the bridge table:
    http://www.nyscanals.gov/exvac/boating/bridgeheights.html
