Click for Dyna
Click for Quantum
Click for Horizon
Click For Affinity
Click for Platinum
Click for Sea Spirit
Go Back   YachtForums.Com > YACHT & BOAT FORUMS > SportFish Yachts > Post Yacht > fuel tanks 86 46'
Reply
fuel tanks 86 46'
Old 09-09-2009, 01:19 PM   #1
stevef4
Registered User
fuel tanks 86 46'
anybody know how the engines draw down the two tanks?
stevef4 is offline   Reply With Quote
Old 09-09-2009, 02:14 PM   #2
Marmot
Senior Member
Quote:
As fuel is metered into the engines it is replaced by fuel that is stored in the tank(s). That process eventually lowers the level of the tank(s).
Is that what you wanted to know?
Marmot is offline   Reply With Quote
Old 09-09-2009, 02:16 PM   #3
NYCAP123
Senior Member
NYCAP123's Avatar
Depends on the boat. Some have one tank feeding each motor. Others have a connection between the tanks that then goes to each motor. The best system is for the cross-over to have a valve so you can seperate the systems; run them together or all out of one. Look near the bulkhead in your engine room for a cross over pipe or follow the fuel line from a tank.
__________________
"Some went down to the sea in ships."
NYCAP123 is online now   Reply With Quote
Old 09-09-2009, 02:19 PM   #4
stevef4
Registered User
The tanks are different sizes, so does one tank replenish the other tank at a certain level? with 2 size tanks it shouldn't be one tank dedicated to one engine
Old 09-09-2009, 02:36 PM   #5
NYCAP123
Senior Member
NYCAP123's Avatar
Sounds like you have a single main tank with a reserve. Again, it could be one to the other or you could have to switch tanks manually. Used to work on a 440 Carver that had 2 main and 2 reserve tanks. There were no cross over valves and each tank fed one engine. There was a valve for switching to reserves. I once moved a 36 Carver with just enough fuel to get to the dealer. About 1/3 of the way there the port tranny blew leaving one engine pushing the whole boat and sucking fuel fast. There was no way to transfer fuel from one tank to the other (not even a garden hose for syphoning).
The best thing is to just follow the fuel lines to figure out what kind of system you have. What kind of boat is it?
__________________
Old 09-09-2009, 04:18 PM   #6
Marmot
Senior Member
It sounds like these tanks are fore and aft rather than one on each side, is that correct? Generally, when there are two engines the two tanks are the same size and mounted to each side of the boat. They are often valved so they can be cross connected to feed both engines from one tank, an engine from the tank on its side of the boat, or both engines from both tanks at the same time. This arrangement allows you to manage list or leaning toward one side or the other by using fuel to balance the boat.
If your tanks are fore and aft, they are probably sized to fit the available space and one may well be much larger than the other. You should still be able to feed both engines from one tank and may be able to feed separately. If you have diesels you will have a fuel return line from each engine to a tank. You may or may not be able to switch the return from one tank to the other. This could create spillage problems if both engines are drawing from one tank and the returns are going to the other (full) tank.
It is important that you trace the fuel system and understand how the fuel lines are valved and what options you have available to feed fuel to each engine and generator and where the returns are routed. It is not a difficult as it may first appear and knowing the system well will make your boating a lot more pleasant and much safer.
Old 09-11-2009, 04:04 PM   #7
mwwhit1
Registered User
I have a 1984 43' so they should be the same setup. The rear tank feeds the starboard engine as well as the generator. It is slightly larger because of the generator (20-30 gal?). The front tank feeds the port engine. You should be able to follow the fuel pickup line into each primary fuel filter as well as the fuel return line from each engine's fuel cooler to confirm this.
You probably also have a transfer pump plumbed between the two tanks with a switch on the bridge helm and a breaker on the main electrical panel you want to leave off unless using it. This allows you to transfer fuel between the two tanks in either direction. Because the rear tank is taller than the front tank to fill the space under the cockpit, there is no manual valve to transfer fuel because it could overfill the lower front tank. The pump allows the transfer while also preventing the natural syphon from the rear tank to the front tank because of the physical fuel level difference in the tanks.
Hope this helps.
mwwhit1 is offline   Reply With Quote
Old 09-30-2009, 11:30 PM   #8
midocean
Registered User
Hope this helps.
Finally a Post owner giving advice about a POST! I have an 85 47' Ditto on what this guy just said. Also, mounted on the rear of the aft tank is the transfer pump to get more fuel from that tank if you wish.
__________________
47' Post "Post Script", Destin, Florida
midocean is offline   Reply With Quote
Old 10-01-2009, 01:18 AM   #9
K1W1
Senior Member
K1W1's Avatar
Quote:
It is good to have participation from those with intimate knowledge for sure but in the absence of such as appeared to be the case when the thread was started 3 weeks ago any sensible advice is better than none.
I don't see anywhere that you added your own experiences to the thread before just agreeing with another poster.
If you take the time to read the first posts you will see that Marmot has actually posted a reasonably accurate description of the system without claiming to have owned or seen one, this was done soon after the original question which should have been sufficient to help out the person who asked the question.
__________________
Cheers,
K1W1
K1W1 is online now   Reply With Quote
Reply
Thread Tools
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is Off
HTML code is Off
Forum Jump
All times are EST. The time now is 04:28 PM.
Click for FLIR
Click for Moonen
Click for ISA
Click for FLIR
Click for Crescent
