Click for Glendinning Click for Westport Click for Nordhavn Click for YF Listing Service Privacy Matters
Plywood Separation Under Fiberglass Cockpit Side
Discussion in 'Post Yacht' started by svalliant, Feb 8, 2009.
  1. svalliant
    svalliant New Member
    CAMBRIDGE MARYLAND
    i HAVE ROT AND THE PLYWOOD IS SEPARATED BETWEEN THE FIBERGLASS ON THE TRIAGULAR SIDE OF THE COCKPIT ABOVE FUEL FILL 1982 42 POST HAS ANYONE DONE THIS REPAIR BEFOR NOT SURE HOW TO PROCEED THINKING i NEED TO CUT OUT THE INSIDE FIBERGLASS AND REPLACE THE PLYWOOD AND THEN RE-FIBERGLASS HELP
    SKIP VALLIANT
    A picture would help here, but it sounds like you're on the right track. All rot and then some has to be cut out completely. The whole piece of ply should be replaced with marine grade ply, and then reglassed. Is this a structural componant? If this is the corner at the transom the damage may go much further and should probably be left to a professional. Are you able to find where the water got through? Take it back to the source and begin replacing from there.
