Click for MCC
Click for Nautical Structures
Click For Affinity
Click for Westport
Click for Quantum
Click for Horizon
Go Back   YachtForums.Com > YACHT & BOAT FORUMS > Sailing Yachts > Perini Navi Yacht > New Build: Perini Navi "C.2166"
Review Tools Rate Review
Perini Navi contracts new project "C.2166"
Hull identification number "2166" is one of the latest yachts being built by Perini Navi ITA. She is a 59-meter blue-water sloop with sleek lines and timeless elegance. Modern in design with the Perini Navi trademark, this sloop when completed will be 59-meters of sailing luxury.
At first glance, the renderings appear to suggest that 2166 will be nothing 'over the top' different from their other sloops built. However, closer examination reveals details that will slowly become customary as each new build is completed with them.
For example, the aft stair-case that will flow from the fly-bridge to the aft main deck. This feature has been incorporated on a number of Perini Navi's recent deliveries including the "Tamsen", "Salute" and the 2166's new build sister, 2150 of the same length but she will have a Ketch rig. The aft stair is sure to be a feature in upcoming builds.
Another of the detail features in the 2166 build is the small forward cockpit -if you will- located forward of the mast base. The small space will be fitted with modern outdoor seating and tables to serve. A wooden wrap-rail will compliment the wooden tables. This space forward of the superstructure-though larger-can be seen on Perini's last delivery, the Salute.
Two roller furlers will spread the genoa and jib at the command of a button while the in-boom main sail will be ready to be deployed at a moment's notice. The mast will be strengthened by the customary back stays and side rigging.
Specifications:
LOA: 192 ft / 58,60 m
LWL: 165 ft / 50,43 m
BOA: 37 ft / 11,39 m
Draught: (keel up) 13 ft / 4 m
Draught: (keel down) 39 ft / 12 m
Hull: Aluminium 5083
Superstructure: Aluminium 5083
Maximum displacement: 565 tonnes
Gross registered tonnage: 498 tonnes
Engines: CAT C 32
Maximum power 938 Kw
Speed: at maximum power 15.50 kt
Range: 4.100 nm @ 13 kt
Fuel: 58.000 lt
Water: 20.000 lt
Main mast height above DWL 250 ft / 76.30 m
Total sail area 35.230 ft² / 3.273 m²
Classification A.B.S.: Maltese Cross A1 Yachting Service – AMS + MCA
Perini Navi
Via Coppino 114,
55049 Viareggio,
Italia
Phone + 39 0584 4241
http://www.perininavi.it
Review Tools
Rate this Review
Rate this Review:
Forum Jump
All times are EST. The time now is 05:32 PM.
Click for Christensen
Click for Queenship
Click for Crescent
Click for Platinum
Click for FLIR
Click for ISA
