Click for Nordhavn Click for Westport Click for YF Listing Service Click for Northern Lights Click for YF Listing Service
Advice on buying an older Ocean
Discussion in 'Ocean Yacht' started by SMR-PILOT, May 31, 2013.
  1. SMR-PILOT
    SMR-PILOT Member
    Santa Marta, Colombia
    Need help. I just sold my 98' sea ray 540 SD, which I loved and had no issues with. Now I'm looking for something more comfortable for the family, with a larger interior. I don't want to spend much money as I don't really use the boat so often (probably 3 o 4 times a month, 3 hour cruise, I don't fish). Now, I've looked around and it seems like the best bang for the buck are ocean yachts. Their desgins on the late 80's boats are much better than the more expensive boats like bertram, hatteras, etc. They have very simple, classic lines that never seem to get old, which I love. I think I would either go for the 55 o 63, 1987 to 1993, if possible with the 71 series detroits (I own work boats with both 92 and 71 series, and I definetily want to stay away from 92's). Is there something that I should watch out for with these boats? Like I said, I only use it for light cruising, I don't care much about speed, riding capabilities or seaworthines. The area I cruise only has one rough spot about 4 miles long, and it's only half a mile from the coast. Should I spend the extra money for something newer, considering I won't use it so much?
  2. RT46
    RT46 Senior Member
    Ocean might be what you are looking for.
  3. ReeLaxin
    ReeLaxin New Member
    Miami
    I have a 1983 55' Ocean I am doing a complete restoration on now. I love Oceans, great floor plan, I like the 8v92's 735 hp.
    I managed, maintained a 63' Ocean. The boat was a 1987, the same owner owned it from 1988 to 2009. I took care of it for most all of that time. It was a pretty good boat all of the way around for what it was. We never had any structural issues on it. Getting to the impellor on the generator was so bad, we had a hatch cut in the bulkhead behind it. The boat ran pretty good and had a good layout. For what you're doing it would be a pretty good boat. The only problem is I'm pretty sure they all came with 12v92's, and the 55's all came with 8v92s......but I'm not totally sure.......if you go newer.....such as mid to late 90's, many came with cats or mans as well. The origional 12v92's went 5500hrs, towing a 35' Marlago around most of the time. After they were majored, they were never as good and never problem free.....
  5. BJG
    BJG New Member
    Huntington Beach, CA
    I bought a 63’ Ocean a few years back in Florida, and we brought it to CA last year. The amenities are good, the boat is solid. If you are going to be using the boat for cruising and some fishing, Oceans are a lot for the money. If you are going to be doing a lot of ‘hard’ offshore fishing or looking for a battlewagon that you can take in any kind of bad weather, Ocean may not be the boat for you.
    We have not had any issues with our boat, but reality is that I will lay up an extra day before I go out in any severe weather. I saved big bucks buying our Ocean over the battlewagon type boat, and for my use…. It was the right choice… not to mention my family really enjoys that amenities too. Hope this helps.
  6. SeaEric
    SeaEric YF Historian
    out on the dock
    I've sold hull # 1 of the 66's twice now. Her original owner previously owned a 63 and worked with Ocean on his new 66 to "fix" some of what he thought was wrong with his 63. This particular 66 was cruised only and never fished. She was in above average condition and a remarkable bargain at her last sale in July 2012. Power was a pair of 12cyl MAN's which had proper care and scheduled maintenance to the letter of the MAN protocol. They ran great.
  7. SMR-PILOT
    SMR-PILOT Member
    All good info. Thanks.
  8. jemane00
    jemane00 New Member
    Noumea, New-Caledonia
    Hin
    I have a 1982 55' Ocean. I'm trying to locate the plaque with the Hull Identification Number on my boat. Other than that do you have any plan from your boat ?
    Many thanks !
  9. Capt J
    It should be on the transom on the STBD side.
  10. jemane00
    jemane00 New Member
    Thank you for your prompt answer CaptJ. However I'm currently away from home, could you please be more precise about the transom. Even translated still not easy for froggies to understand the location.
    Cheers !
  11. ranger58sb
    ranger58sb Senior member
    Chesapeake Bay, USA
    Outside stern of the boat (transom), right side (starboard), probably within about 5 inches below the rub rail. Not a "plaque" but rather a stamping, perhaps slightly filled with paint and/or wax...
    -Chris
  12. SMR-PILOT
    SMR-PILOT Member
    Interesting. I really liked the 63s. But then I found a 1996 66 for sale near to where I live and will be inspecting it on the 16th of December. I have a copy of a survey done in October. According to the survey, the boat makes 16 knots at crsuise speed. It has really good engines, cat 3412´s, but I thought that the cruise speed would be much higher. I saw a video of a 63 with mans making 21 knots at 1750 rpm, so I know it´s not an issue with older boats. The owner says that it´s normal for it to only make 16 kts, as the boat is getting old. Also, one engine was running at 1750 while the other at 1840. The hull seemed to be clean at the time of inspection. The engines have just over 2000 hourse supposedly. What should I watch out for? or is it really normal for the cruise speed to drop so much?
  13. Capt J
    Well, first off, 3412's should turn 2300RPM's WOT, if that's all they're turning you have some very very serious issues with them. Yeah as the oceans get old they get a little heavier. By 2009 we had cut 3" of pitch off of the props on the 1987 63' I managed.....BUT, she didn't lose but a knot of speed.....
  14. jerseyguy
    jerseyguy New Member
    forked river, n.j.
    Battlewagon
    Greetings , Although I have been a member for years this is my first post so bear with me if I don't go about it the correct way.
    I just read a post where someone said "Ocean Yachts are not battlewagons"n I sincerely have to disagree about oceans not being good "Battlewagons" I personaly have owned a 1985 46' with DD671tib 485hp since 2003 and made several trips from home port in Barnegat bay NJ straight to Martha's Vineyard in all kinds of seas with the Wife and kids on board ( until they went off to college). There were times we were off shore in 8-12 ft seas running a b-line to South Jersey in South East winds and she proved her self over and over with out any major problems. she took many waves up and over her bridge and brought us home. I gained most of my sea experience on this boat. Made my mistakes and learned from them. These DD671tibs are the toughest engines I know of in this class of boats.
    I'd take an ocean out against any battle wagon of the same size any day. I personally have met and know many of the guys who built my Ocean right down to the man who ran the crew that laid the hull,( they are still around doing repairs and refits on older Oceans on the east coast ). Yes I had to reinforce the keel, replace the tanks and @ 3000hrs I finaly gave her out-of-boat major overhauls. To this day I never broke down, she always brings me home.
    I can't believe someone would actualy say Ocean Yachts are not Battle Wagons. They are true battle wagons, belive me I have put mine through the test.
    Regards , Dom
  15. SMR-PILOT
    SMR-PILOT Member
    Bought the 66
    So I trialed the boat a couple of times before buying it. The first time it was only making about 16 knots and putting out a lot of black smoke. Obviously some turbo issue. Told the owner I could consider the boat if he fixed the turbos, so he did. Then I tested the boat again and this time it was making 21 knots at 1900 rpm, which was not bad. But I noticed the temperatures were running a bit high (180 on port and 195 stbd). Now, normal temperatures should be between 170 and 180 right? also had some vibration on the port side, and it would smoke a bit at idle. I finally decided to make a very low offer considering the money I know I need to put into the boat, and the owner accepted it. I know the engines need some work, but in my opinion, 3412s are good engines that wont take much to bring up to shape. I hauled the boat out to install a new westerbeke generator. I bought a 15 Kw Gen, which i think should be enough. the old one was a 25 kw but in terrible condition. I´m also painting the hull with a dark blue. Would aprpreciate any advice on the engines.
      103.6 KB
      105.2 KB
      81.1 KB
  16. RER
    RER Senior Member
    Newport Beach CA
    Guages or gun? Cats run hotter than Detroits. It might be time to service the heat exchangers and it looks like you accounted for that in the price - it's good to know what you're buying.
    You might want to think twice about painting the hull dark blue. I don't think the Ocean 66 molds have the quality for it. The ones I've seen have a lot of wavy-ness and woven roving imprint that doesn't show in light colors - and that's before we get into maintaining it.
  17. Beau
    Beau Senior Member
    Beaufort, NC
    Also, I've heard that down south the dark blue exterior can really change the heat index for the areas below decks? dunno. Nice boat , good luck with her.
  18. SMR-PILOT
    SMR-PILOT Member
    Thanks for the advice. Unfortunately I´ve already bought the paint and they´ve started working on it, so I guess I´ll just have to see how it turns out. Did service the whole cooling system, and found the heat exchangers to be very clogged. I´m worried about the slight smoking at idle, plus an oil sheen in the water coming from the exhausts. I´m guessing the injectors need servicing (it´s light colored smoke, white/blueish). The engines only have 2000 hours on them so I don´t think they need an overhaul yet.
  19. RER
    RER Senior Member
    Newport Beach CA
    If the boat runs well otherwise, you may want to put some hours on it before you do anything with injectors.
    I've seen boats that have been sitting with bad turbos, fixed the turbos, and the idle smoke and fuel sheen goes away once the boat is run up at cruise speed again on a regular basis.
  20. Capt J
    I agree.....sometimes the piston rings don't completely seal after sitting a while...sometimes it's just the fuel quality.......I too would recommend running it a while before doing anything with injectors........
