Click for Burger Click for Westport Click for Westport Click for Ocean Alexander Click for YF Listing Service
hinged mast on 423 Classico
Discussion in 'Ocean Alexander Yacht' started by amostad, Jan 23, 2011.
  1. amostad
    amostad New Member
    Anacortes, WA
    I am considering buying a 423 Classico with a hinged mast. My boat house requires that I drop the mast due to height limits. Does anyone have photos or drawings on how one actually drops the mast. Is it too heavy with the radar for one person to lower by hand assuming you had a rod mounted part way up the mast that can pivot as you lower it? Thanks for the ideas.
  2. geologydave
    geologydave New Member
    Cape Coral,FL
    I realize that this is an old question but thought I would respond with my experience. Standing on the flybridge I used a .5" line tied to the radar mount and lowered it that way by myself to some timber blocks I stacked on the lazerette to rest the mast in a horizontal position. My radar is an open array furuno. I was not easy but not impossible. I would suggest that you might want to be at least 200lbs and have somewhat above average upper body strength.
    Like all things on this planet, it is a bit more difficult going down than up. I suggest it is a two man operation, to be on the safe side. Probably using a ratchet winch of some type would be the smart way to do it alone.
    Regards
  3. amostad
    amostad New Member
    Anacortes, WA
    Thanks, Geologydave. I found the solution. I used two 125 pound gas pistions like you would see on a stationwagon back window. I can now raise or lower the mast with one arm. I just had to add mounting plates and backing on the mast sections to mount the pistons to. If you care to contact me, I can provide photos of the finished project. amostad mostad@mostad.com
  4. geologydave
    Cape Coral,FL
    I would love to see a photo. Much more elegant solution than my caveman approach. can you post the photo here?
    regards
  5. amostad
    amostad New Member
    Anacortes, WA
    photo of gas piston for mast
    Here are photos of my 125# stainless steel gas piston. These allow me to raise and lower the mast with one hand on my Ocean Alexander Classico 423.
    You are more than welcome to use this plan. Remember, there is a 1/4 inch aluminum backing plate behind each stainless outside plate. IF you would like more photos please contact me at the email address in the February posting.
    amostad
  6. amostad
    amostad New Member
    Anacortes, WA
    second attempt at posting the photo
    This is my second attempt at posting a photo os the mast lowering pistons mentioned above.
  7. Safeguard
    Safeguard New Member
    Wilmington nc
    Do you still have Classico o.c.?
    I am having to replace and repair windows on my 2003 o.c. Classico and it looks like cause is manufacturing design problem?
    Carolina Girl
    Wrightsville Beach, n.c.
  8. Clamdigger
    Clamdigger New Member
    New York
    Dear Amostad,
    I saw your solution on Yacht Forum. It is absolute genius in its simplicity! Congratulations. Would you be able to send a copy of the plans and name of the provider of the brackets and pistons? I would be most grateful.
    Once again my congratulations on your solution.
  9. leeky
    leeky Senior Member
    Florida
    Hey, Clamdigger -- Welcome to YF!
    Don't hold your breath while waiting for amostad to reply to you. He hasn't logged in to YF since October 20, 2013.
    You can "Start a Conversation" with him and hope that he receives email notifications when someone tries to start a conversation with him. (To start a conversation with him click on his member name in post #6; then click on "Start a Conversation;" then type your message; then click on "Start a Conversation" below the message.) Do you feel lucky?:D
