Click for Christensen
Click for Dyna
Click for Lurssen
Click for MCC
Click for Sea Spirit
Go Back   YachtForums.Com > YACHT & BOAT FORUMS > Trawler Yachts > Nordhavn Yacht > Review: Nordhavn 55' Trawler
Review Tools Rate Review
Photo Caption: An unusual touch is the almost circular bath tub, with a shower overhead. Again, portholes are used in all the right places, such as venting the humidity that fills a shower after use. Notice the sturdy shower door and hardware. Why so strong? Spend a week in true offshore conditions and you'll see why stout hinges are a protocol.
Photo Caption: Nicely fitted in, just forward of the pilothouse, the VIP stateroom offers a double berth, plus bed lamps and a bureau as well as a hanging locker. It can also double as an off-watch station for crew during long passages. The VIP accomodations are warm, inviting and comfortable. For the cruising couple, the VIP can also serve as storage, as well as a private escape.
Photo Caption: The N-55 is powered by a John Deere 330 hp diesel. De-rated and highly reliable, this single engine set-up affords increased engine room space and much better mileage. Because the N-55 is a full displacement hull, an additional engine would not push the hull much faster, yet it would consume twice the amount of fuel. Adding to it's range, Nordhavn’s modified hull design uses broader aft sections then typical trawler hulls, which adds stability, reduces “squatting” and improves efficiency. Although the N-55 is only a single screw, it's 50' waterline, coupled with a bow-thruster make quick work out of tight slips.
Photo Caption: The engine room is insulated with Technitron fire proof foil and 2" of leaded foam, topped off with gray paint and perforated aluminum sheets. No wood is used in the engine room. In addition to the main engine, this cavern contains a Northern Lights 20kw generator, Dayton blowers, and a Halon system. Notice the number of access hatches to the bilge, as well hatches in the ceiling that open to the salon above. The ultimate in convenience for passing parts and trading tools.
Currently...
Nordhavn's dealer network is expanding around the world, with offices established in Rhode Island, Florida and the UK. Their new designs have made quite an impression on the big bow, blue water scene, as more people recognize their rugged durability and long range capability.
The N-55, now one of twelve long range cruisers ranging from 35 to 76 feet, is sure to be one of the most popular Nordhavn models. It's a BIG little boat that will go anywhere... with fuel to spare. But... be prepared to wait. By mid-2005 there was a 15-boat backlog for the N-55, which for now, is being built at a rate of 9 boats per year. Clearly, these "slower" boats are going fast and Nordhavn is winning the race... at 9 nautical miles per hour.
To fully appreciate these boats, you need to get up close. The Nordhavn 55 has presense. This little 55' thinks it's a freighter. One excursion into North Sea swells... and you will too.
<end>
Story by Chuck Gnaegy and Carl Camper.
SPECIFICATIONS:
LOA: 55’0”
Beam: 18’0”
Draft: 6’0”
Disp.: 120,000 lbs.
Fuel: 2,250 gals.
Water: 600 gals.
Power: John Deere 330 hp Diesel
Range: 3,000 nm @ 8.25 knots
Nordhavn Yachts
34179 Golden Lantern, Suite 101
Dana Point, California 92629
http://www.nordhavn.com
Review Tools
Rate this Review
Rate this Review:
Forum Jump
All times are EST. The time now is 03:28 AM.
Click for Oceanco
Click for FLIR
Click for Crescent
Click For Dockwise
Click for ISA
Click for Moonen
