Click for Lazzara
Click for Dyna
Click for Moonen
Click for Trinity
Click for Quantum
Go Back   YachtForums.Com > YACHTS FOR SALE > Motoryachts For Sale > Motor Yachts Up To 49' > 45' Monk Overseas Classic
Reply
Old 10-16-2007, 06:36 PM   #1
winter harbor
Registered User
* Year: 1989
* Price: US$ 249,500
* Hull Material: Fiberglass
* Engine/Fuel Type: Twin Diesel
Specs, Equipment and Information:
Builder: Overseas Yachts Designer: Todd Harris Design w/Ed Monk
Dimensions
LOA: 45' Beam: 14'6" Displacement: 27,000
Draft: 3'6"
Engines
Engine(s): Cummins Engine(s) HP: 210 turbo Engine Model: 6BT-5.9
Hours: 2700 Cruising Speed: 8 k Max Speed: 12 k
Tankage
Fuel: 175 Water: 180 Holding: 42
Salon
Large salon welcoming with a lower helm, beautiful teak interior, overhead electronics console and panel. Electrical panel and generator controls are at the lower helm. There are port and starboard entrance doors, a custom L shaped sofa with drawer storage, A HI-LO dining table.
Master Aft State Room
This wonderful aft stateroom features a queen centerline bed with custom cover.
*Flanked Port and Starboard by windows as well as 2 large aft windows, this Master stateroom is filled with fresh air and sunshine.
*Hanging lockers (ladies,full length)with drawer storage port and starboard.
*Dressing table with mirror and seat located on the port side of stateroom.
*Entrance to the master head is forward and to starboard and features an enclosed shower with tub, corrian counter tops with molded sink, hot and cold pressure water, and a new Tecma Head.
* Bathroom is mirrored and is finished in beautiful teak.
* The aft stateroom is fully air conditioned and heated.
Aft Guest Quarters
*Forward cabin has an oversized V-berth.
* With hanging locker,storage,Book shelves, reading lamps,and a privacy door.
* Forward cabin equipped with heat and AC. Two port holes, an overhead hatch and access to the anchor rode.
Guest/Day Head
Just aft and to starboard is the private forward head, counter tops are Corrian, with a molded sink, hot and cold water, new Tecma head, and under counter and wall storage.(Head is Capable of Conversion to head W/shower)
Galley
*Galley is down and to the Port with wonderful ambiant light!
* U shaped with lots of counter space and storage.
*Double stainless sink with W/ Seagull water purifier in spray!
*Princess 3 burner electric Stove w/oven.
*Tundra upright 120vac/12vdc refrigerator w/freezer
*Sharp Microwave
*Teak and holly sole
Electronics
Raymarine Duplicates at Flybridge and Salon Helm Station. Radar w/overlay capability to GPS, GPS, Deth sounder, Fish Finder, Temperature, log
Compass: (1)Magnetic at each Helm; on built into Autopilot on flybridge
* Autopilot: Autohelm,
* ST7000 Flybridge
* ST6000 Salon
* VHF Radio (3 aboard)
Electrical
12VDC/12VAC
30amp AC and 50amp AC capabilities w/isolators
(2)12 vdc Starting Batteries- 8D
(1)12vdc genset starting battery
(4)6vdc house batteries
12vdc and 120 vac at flybridge
120 VAC GFCI breakers at several locations
Genset: 8KW Kohler (2005) 300hrs.
Battery Charger: TruCharge 40amp.
Inverter: StatPower 1500 w/remote on-off
Engines/Engine Room
Twin Cummins Diesels
210 hp Turbo
Model 6BT-5.9
Borg-Warner Velvet Drive Transmissions 2 to 1 Ratio
*Engine Room:
2 Heat pumps in engine room provide Air Condition and heat
Oil"X-change-R" connected to each engine and genset!
6 gal hot water heater
Sanitation-Worth Noting!
This Monk was refit with a Tecma Head Sanitation System. New in 2004!
Tecma is a silent flush fresh water head
Porcelain toilets use 0.9 liters of fresh water to flush-
Flushes directly to the 42 gal. holding tank-
Holding tank can be vacuumed empty or when legal, pumped over board using it's own pump-
Deck/ Flybridge
DECK: Non-Skid on all decks(no teak on decks) Teak hand rail all around-
Anchor pulpit is re-enforced as is the anchor self launcher
Anchor pulpit houses the deck and anchor wash down connection and the dockside potable water inlet. Access ports both sides
Lewmar windlass windlass w/a 44# Lewmar Quickset plow anchor
Transom deck has a hot and cold outside shower
FLYBRIDGE: Full bimini top with 3 sides closed.
Two Full curtains allow for full Enclosure.
Seating for eight has storage beneath.
Mast and boom arrangement allow bringing aboard dingy when necessary.
Dingy may also be stored on transom snap davits
Anchor may be launched/retrieved from flybridge or pulpit
* Misc Items
* Follow me TV unit w/dish
* Samsung DVD/VHS player
* Zodiak 9.4 dingy and 3.3hp Mercury outboard
* 44# Lewmar quickset ancho
* Winter in heated storage-15 minutes from major airport
__________________
Winter Harbor -"Nothing so lovely as messing about in boats"
winter harbor is offline   Reply With Quote
Reply
Thread Tools
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
All times are EST. The time now is 05:07 PM.
Click for Quantum
Click for Lurssen
Click for Shadow
Click for NorthCoast
Click for Christensen
Click for Westport
