Click for Nautical Structures
Click for Westport
Click for Heesen
Click for Broward
Click for Christensen
Click For Dockwise
Go Back   YachtForums.Com > YACHT & BOAT FORUMS > Motor Yachts > Marlow Yacht > Info wanted on Marlow Yachts
Reply
Old 12-04-2006, 05:38 PM   #1
Hef
Registered User
Looking at a Marlow build or pre-owned. Would sure like to hear any positive or negatives - I guess particularly the latter on this builder before we launch in that direction. Previous vessel was an Offshore which we thought a lot of.
Help!
Hef is offline   Reply With Quote
Old 12-06-2006, 06:05 PM   #2
yachtbrokerguy
Senior Member
yachtbrokerguy's Avatar
The Marlow has an unusual bottom design with both prop shafts enclosed in twin keels, giving more protection to the props. I was at a local yard where a Marlow had been hauled to do some repairs. The owner found some very skinny water in the Bahamas and put some scratches in the bottom paint and through some gel coat, but the props were OK and they were able to continue their cruise. Marlow has a fancy name for these twin keels but it is much more common on British and Dutch built boats than US ones.
Tucker Fallon
yachtbrokerguy is offline   Reply With Quote
Old 12-06-2006, 07:18 PM   #3
Kevin
YF Moderator
Kevin's Avatar
Post
Taken from the YachtForums.com review of the Marlow 57 RPH:
Quote:
“Strut Keel” technology, a design which employs twin keels at the stern, in addition to a shallow single centered keel.
Hef, if you haven't already checked out the review be sure to take a look.
Kevin is offline   Reply With Quote
Old 12-13-2006, 01:31 PM   #4
J. Dunbar
Registered User
I observed a significant difference in the Fit & Finish between the Taiwan built verses the China built Marlow's. This may or may not be the case as their efforts to build in China has increased.
I've come to realize that all Marlow 65's and 70's have been and will continue to be built in Taiwan. The 65 is the plum transom while the 70 is the reverse transom. Both boats have the same distance from stem to transom.
It does appear the 70's may run a little better because of the extended planning surface aft. I sea trialed a 70 , which does run better than 20 knots.
The two 65's I have sea trialed have not gone quite that fast.
All of the 65's and 70's are coming out of one mold while the 72 and 78's are coming out of another mold in China. The difference between the 72 and 78 is just like the difference between the 65 and 70.
I have also read that the new plant in China is "state of the art" . And very environment friendly .
J. Dunbar is offline   Reply With Quote
Reply
Thread Tools
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
All times are EST. The time now is 03:20 AM.
Click for Broward
Click for Shadow
Click for Oceanco
Click for Lazzara
Click for Moonen
