Click for Walker Click for Abeking Click for Burger Click for Westport Click for JetForums
jupiter inlet local knowledge?
Discussion in 'Marinas & Waypoints' started by Chris W, Nov 21, 2010.
  1. Chris W
    Chris W Member
    stuart florida
    good day all,i am running an80ft,6ft draft sailboat in stuart now.got to haul out at seminole boatworks in afew weeks.any local knowledge of jupter inlet here?i know alot is wx dependent.i may come down icw from stuart after i do a recon trip in the tender.i see no fixed bridges on charts but am worried about airdraft(105ft mast).
    any info would be appreciated.
    cw
    A chart will show you if there are any fixed bridges between Stuart and Cracker Boy on the ICW. I cannot remember on whether or not if there are, but I am sure you are capable of looking on your chart.
    With 6' of draft I would be very very leary of using Jupiter Inlet. The only instance I would consider using it with your size would be right at high-tide (or very close to it) AND on a calm day.
  4. Chris W
    Chris W Member
    stuart florida
    jupiter inlet
    thanks for that both of you.i have asked half a dozen locals and heard half a dozen differant opinions.i am leaning toward the icw route as any trouble would not be the type to make the news.
    on a sad note i saw on the news last night today is the day the charter capt will be laid to rest.
    when i go,i would hope to go doing something i loved doing.not because someone is texting while driving next to me.
    have a good day all and count your blessings.
    the chart shows nothing to keep me from coming to seminole boatyard from the north,but i still want to do a recon with the tender first.i will also ask the fleet of charter boats in jupiter but they are mostly smaller like the one involved in the accident not much draft.
  5. NYCAP123
    I always try to stick with the main shipping inlets (Ft. Pierce, Lk. Worth, Pt. Everglades) whenever possible. It's just safer. You should have no problems with the ICW. All bridges that don't open are 65'+, and your draft should be OK. Just check the current ICW conditions & alerts.
    The poster states he has a 105' mast. Which would be a problem if there are fixed bridges along the way, even at 65'
  7. NYCAP123
    Missed that. Hmmmm. Still not a problem though. I don't believe there are any fixed bridges between Stewart & Jupitor.
  8. Chris W
    Chris W Member
    stuart florida
    air draft is just as important as icw depth
    yes i would certainly make the news if i tried to squeak under the bridge in wpb.maybe i could use the publicity to find a new job though.on a motor boat anyway.haha:D
  9. NYCAP123
    Demasting a sailboat (or leaving outriggers on a bridge for that matter) is seldom good for career advancement, but it does make for amusing video.:D
