Click for Quantum
Click for Oceanco
Click For Affinity
Click for Crescent
Click for Nautical Structures
Click for Heesen
Go Back   YachtForums.Com > GENERAL YACHTING DISCUSSION > Marinas & Waypoints > Eastern Seaboard to Lake Onatario
Reply
Old 09-11-2009, 05:50 PM   #1
PropBet
Senior Member
PropBet's Avatar
Has anyone made the trek from New York, up through the IC waterway to Quebec (essentially getting into Lake Ontario)?
Trying to figure the quickest path from mid way up the eastern seaboard area to Lake Ontario. Would be traveling in a 65' trawler, drawing 5' of draft, and a 23' air draft.
Any insight would be appreciated. I seem to recall a thread or two of discussions on it, but after a half doz. searched, I came up with very little. Google gave me a pretty wide scope, so I was hoping to narrow that down with hands on info.
Cheers-
~PB
PropBet is online now   Reply With Quote
Old 09-11-2009, 06:42 PM   #2
NYCAP123
Senior Member
NYCAP123's Avatar
The ICW will take you to Norfolk, Va. then into the Chesapeake Bay where you can go to the ocean or up into the C & D canal to the Deleware River down to Cape. May, NJ. That's as far as you're going on the inside with that boat (too many shallows through NJ) untill you enter NY harbor. Once in NY I think this link should help: http://www.nyscanals.gov/
__________________
"Some went down to the sea in ships."
NYCAP123 is online now   Reply With Quote
Old 09-11-2009, 07:11 PM   #3
PropBet
Senior Member
PropBet's Avatar
Quote:
OK, you kind of lost me going a couple of different directions there. Looking at a map, I can't seem to follow that particular route.
Notwithstanding, what route would you consider using to get from the North Carolina coastline to Lake Ontario?
Old 09-11-2009, 07:39 PM   #4
NYCAP123
Senior Member
NYCAP123's Avatar
I always take the ICW eastern branch past Coinjock to Norfolk. (Dismal Swamp route tends to be slow and often shallow). From there if the seas are light I head outside to Ocena Beach, Md., then up to NY although you would probably stop around Atlantic City. If the seas are rough I go from Norfolk, up the Chesapeake to the C&D canal, over to the Delaware River and back down to Cape May, NJ. The inside from there is nearly impassable for a 5' draft, especially south of Atlantic City. Just not worth messing with, but the inlet areas are fine if you need to come in at A.C., Barnaget, Manasquan or wherever.
Once to NY you'll head up the Hudson. From there I'm a little concerned for your height which is why I refer you to that link. You can get all the info you need about the NYS canals system from that.
__________________
Old 09-11-2009, 08:46 PM   #5
PropBet
Senior Member
PropBet's Avatar
Got it. Thank you.
Old 09-12-2009, 01:06 AM   #6
Capt J
Senior Member
Cheers-
~PB
You cannot get into Lake Ontario from the Hudson River/NYC with an air draft of 23'. There is a bridge on the North side of Troy, NY on the Erie Canal that has an air draft of 20'2. Now keep in mind this is minimum clearance and when I went through it was a bit higher then the published 20'2.
If you can get it to 20'2 then you go up the Hudson, across the Erie Canal to Three Rivers and then north to Oswego, NY and into Lake Ontario and then you just hop across Quebec. If NOT, then you need to take the ocean to the St. Laurence canal which is many many more miles
Capt J is offline   Reply With Quote
Old 09-12-2009, 03:44 AM   #7
PropBet
Senior Member
PropBet's Avatar
Thank you Capt J.
That was exactly the info I was looking for. I appreciate the info.
Old 09-12-2009, 08:36 AM   #8
NYCAP123
Senior Member
NYCAP123's Avatar
Thanks for that Capt. J. I recalled hearing that and couldn't find a way but didn't want to put the kabash on it having never gone that far up myself. The outside run from the Cape Cod Canal up to the Straits of Canso is a lot of open ocean running (about 38 hrs.). When I made that run we left Ft. Lauderdale in Late March and had to leave the boat in the Strairs for 3 weeks due to ice. So it's strictly a late spring to early fall trip. Is it possible to drop your mast and lose the 3'?
__________________
Old 09-12-2009, 10:37 AM   #9
Capt J
Senior Member
Thank you Capt J.
What kind of yacht are you planning on running there? I would really measure what you have. Call the dockmaster at Troy, NY and ask him what kind of clearance is at the bridge. When I went through it was around 22' because the water level was lower. You could also flood the bilges to get the boat down a bit further, it is freshwater and you could just open a seacock and add 10-12" water to the bilge and get the boat down probably 8-10" that way. A friend of mine had to flood the cockpit on a 66' Ocean to get it through.
I was able to get a 75' Hatteras MY down to 18'6 just by lowering the radar arch and masthead. Also a 63' Ocean SF is only 19'6 to the top of the radar on the factory hardtop.
Old 09-12-2009, 01:27 PM   #10
PropBet
Senior Member
PropBet's Avatar
Well, the boat in this scenario would be a GB 59' Aleutian. (I overshot the LOA with 65' in my OP) the specs out of the book are:
Height (DWL to Hardtop)
18' 2" (5.54m)
Height (DWL to Mast)
22' 6" (6.86m)
So that leads me to believe that we could clear it with a stop to remove some gear prior and sneak under, depending on water level and how complicated removing some gear becomes.
The bigger question, all things considered with timing and such is can we doing quickly enough through the channels to get to port in the Great Lakes, and ready for dry storage once the season 'ends' up north, or do we take the leisurely route our around Nova Scotia and then inward.
I can't see any real pro or con to either other than the length of trip. I've read as much as I can on the longer route, and see there are some pros to that in it is a much more scenic route, however adds +/-2 weeks. The objective being 'get the boat up north' balances the desire to take a longer leisurely voyage.
I spent some time in google maps and in my Nav Software and marina lists / locations last night tinkering around with different options. The biggest objective I was up against was understanding the path from NY north to the lakes. Otherwise, both look like they would offer equal options as far as stopping, docking for a night, provisioning, fuel (if needed) etc.
I appreciate your insight.
Old 09-12-2009, 07:52 PM   #11
Capt J
Senior Member
What do you have mounted on your hardtop? You should be able to get to under 20' while still leaving the radar on if it is mounted flat on the hardtop. I don't know the configeration, but it sounds pretty easy to get to where you need to be height wise. The Erie canal route is a lot shorter and faster to the great lakes. You would want to stop in Troy, NY at the city docks and take your stuff down there. Then at Oswego, you can put it back up.
From NYC, you should be able to get to Lake Ontario in 5 days. Another day to the Welland canal, a day to clear customs, go through the canal and you're in the Erie canal. BUT yes, you have plenty of time to get into the great lakes before winter. I'd say you have 4 weeks of time maybe 5 weeks to get there. The Erie Canal is very scenic and was my favorite part of the entire great loop. Check the NY canal system website and see when they go to reduced lock hours. Also, I anchored everynight on the Hudson and Erie canal except Oswego and one night right before that. There were plenty of places to anchor and you could run until almost dark that way.
Old 09-13-2009, 01:36 PM   #12
PropBet
Senior Member
PropBet's Avatar
Outstanding Capt J, I really appreciate the info.
I'll have a look at the boat further and see what / how much would be involved in taking any needed gear down and take some further measurements. Hopefully it's a couple of whips, rather than a dome, or anything else complex.
Again, I appreciate your hands on insight on making the trip and the info. shared.
Old 09-13-2009, 10:30 PM   #13
Capt J
Senior Member
I'm not familiar with that Great Banks, but I would guess you could get the height down pretty easily to where you need to be. A normal Satellite dome doesn't typically stick up that much.
Reply
Thread Tools
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
All times are EST. The time now is 07:07 PM.
Click for Platinum
Click for MCC
Click for Queenship
Click for Westport
Click for Lurssen
