Click for Cross Click for Delta Click for Westport Click for Burger Click for Westport
Licences & Lengths
Discussion in 'Licensing & Education' started by denzil, May 25, 2007.
  1. denzil
    denzil New Member
    Ibiza
    Me again.
    On a side note to my Spanish Licence problem i'd like to pick your brains.
    Lets say you have a licence to 24m. Is this waterline length or LOA. I'm sure i remember reading that waterline length could be used although i now cannot find the legislation anywhere. Any licence brainiacs able to shed some light? If this guy can use waterline length his problem is solved.
  2. GrahamF
    GrahamF Senior Member
    Palma Spain/ South Africa
    From what i understand if you have a yachtmaster ticket it allows you upto 200 tons or 24 meters waterline length. That is what was said to me when i did my ticket.
  3. denzil
    denzil New Member
    Ibiza
    yeah thats what i thought. If that is the same for this Spanish 20m ticket job should be sorted. Here's hoping :)
  4. AMG
    I have never heard of waterline length as a definition of a ships length. The normal is to measure the deck over the hull where it is a closed volume. This is part of calculating the tonnage. A simplified measuring is the overall length without bowsprit, rubrails and swimplatform. The latter normally gives a higher figure.
  5. techmati
    techmati Senior Member
    Athens, Greece
    yes MCA refers to load line length
  6. Garry Hartshorn
    Garry Hartshorn Senior Member
    The IMO refers to 2 methods for measurement to determine crew qualifications and manning
    TONNES GRT.......Gross Registered Tonnes
    Length LBP.........Length Between Perpendiculars usually forward and aft collision bulkheads but sometimes they use the rudderpost or I think it's 90% of the uppermost watertight deck
    However each flag state authority may interperate this as they see fit.
