Click for Christensen
Click for Lurssen
Click for Nautical Structures
Click For Dockwise
Click for Westport
Click for Cheoy Lee
Go Back   YachtForums.Com > YACHT & BOAT FORUMS > Motor Yachts > Horizon Yacht > Review: Horizon 68' Vision Motor Yacht
Review Tools Rate Review
Based on the port side at center, the guest stateroom offers a queen-size berth as well as a third, sofa/couch/single berth, following the classic decor of the other rooms. Ample storage space and closets provide room for comfort all around. With overhead lighting, there is also a small opening window/port for daylight. A 32” TV provides nighttime entertainment.
A fourth, smaller stateroom adds capacity for crew, with a double berth. It features ample storage cabinets and its own ensuite head/shower. It too follows the decor with satin finished wood cabinets and wall covering, plus bedside and overhead lighting.
At the stern, the twin CAT diesels are situated within a 7’ head-room, full walk-around maintenance area. Entry is forward of the stern, through a watertight bulkhead partition/door. The engine compartment is adjacent to the workroom, which provides full system monitors and an air conditioned work area for maintenance.
Engine loads are distributed through flex-mounts on stainless steel plates bonded to the hull girder. Watertight bulkhead entrance doors and full-length stainless steel grab rails add to safety measures. The Vision-68’s twin 1,000 hp C-18 CATs are programmed to cruise at 1900 rpm, moving the vessel at a standard 13.6 knots. At 1300 rpm, she produces 10 knots, which, with a standard 1400 gallons of fuel would easily be enough to reach out to any cruising skipper’s dreams.
The 68’ Vision offers the accommodations of a larger build, but in a manageable size for the cruising couple. For those needing a little more space, a Vision 75' will soon follow. Horizon’s meticulous quality control and excellent manufacturing processes add to this fresh, contemporary Greg Marshall design. YachtForums.com roars a proud Hoorah! for Horizon’s latest progeny.
Another winner by Horizon Yachts!
<end>
Review by Capt. Chuck Gnaegy
Specifications:
LOA: 69.83’
Beam: 20.5’
Draft: 6’
Fuel: 1400 gals.
Water: 200 gals.
Displ.: 110,600 lbs.
Power: 2x 1,000 hp CAT C18 Diesel
Performance: Max 20 knots
Cruise: 10 knots, 17 GPH
Range: 10 knots, 900 nm
For more information contact:
Horizon Yachts
8 Kuang Yang Street
Hsiao Kang, Kaosiung Taiwan
www.horizonyacht.com
Horizon 68' Vision Deck Plans; Top to Bottom...
1. Skylounge / Upper Deck
2. Main Deck / Aft Deck
3. Lower Accommodations / Engine Room
Review Tools
Rate this Review
Rate this Review:
Forum Jump
All times are EST. The time now is 07:11 PM.
Click for Moonen
Click for ISA
Click for Moonen
Click for Quantum
Click for Queenship
