Click for Moonen
Click for Quantum
Click for Horizon
Click for FLIR
Click for ISA
Click for Sea Spirit
Go Back   YachtForums.Com > YACHT CLUBS > The Chris Craft Roamer Club > History & Documentation > hull number help
Reply
hull number help
Old 05-25-2009, 07:32 PM   #1
jmack1578
Registered User
hull number help
im trying to find more info on a 1968 steel hull 41 ft roamer i found one number on the boat h/n 540589 i believe its the coast gaurd registration number. does anyone know where the actual boat serial number is? or is there anyway to find it via the net with the 540589 number. i would really like to find more out about the history of the boat.
jmack1578 is offline   Reply With Quote
Old 05-26-2009, 07:35 AM   #2
SeaEric
YF Historian
SeaEric's Avatar
That number is the Coast Guard Doc #. On the net you can find only limited info here: http://www.st.nmfs.noaa.gov/st1/Coas...esselByID.html
More info may be discovered by ordering an Abstract Of Title (for $25) from the Coast Guard here: https://vcart.velocitypayment.com/uscg/
The Chris Craft Hull ID should be on the boat somewhere. If you find it, you can get more info on your boat here: http://www.mariner.org/
SeaEric is offline   Reply With Quote
Old 05-26-2009, 07:40 AM   #3
Shangri-La
Registered User
Shangri-La's Avatar
I found mine stamped on the frame of the starboard engine hatch cover.
__________________
Kenny
1960 35' Roamer Riviera
http://shangrila.owfish.com
Shangri-La is offline   Reply With Quote
Old 05-26-2009, 09:21 PM   #4
jmack1578
Registered User
thanks guys ill take a look and see what i can find out
Old 06-01-2009, 06:30 AM   #5
jflongwell
Registered User
Hull ID number
I found mine stamped on the wood frame where the generator covers lift out. I was working (what else) on a wiring problem, and as I was slowly lifting me head facing forward on the boat to get out of the engine compartment, there it was.
RDP-38-0503
I also found the Coast Guard number painted on the metal frame.
John
jflongwell is offline   Reply With Quote
Old 07-09-2009, 11:59 PM   #6
hat4349
Senior Member
hat4349's Avatar
Mine is etched into one of the beams in the engine room in front of the battery.
hat4349 is offline   Reply With Quote
Reply
Thread Tools
Rate This Thread:
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
All times are EST. The time now is 10:06 PM.
Click for Platinum
Click for Queenship
Click for Crescent
Click for Heesen
Click for Lurssen
Click for Cheoy Lee
