Click for Delta Click for Abeking Click for JetForums Click for Nordhavn Click for Westport
Hatteras "bulbs" for increased speed & stability
Discussion in 'Hatteras Yacht' started by bray yachts, Jan 25, 2005.
  1. bray yachts
    bray yachts New Member
    Vancouver, B.C., Canada
    It may be of interest to Hatteras LRC vessels that we have retrofitted bulbs to several sizes with great success. The bulbs give a 10% drop in resistance or 3/4 knot increase in speed and almost 50% reduction in pitching. The owner's of these vessels swear by the results.
    Patrick J. Bray
    Naval Architect
  2. alloyed2sea
    alloyed2sea Moderator
    Alex, VA
    Big Nose
    Does that equate to a 10% improvement in economy?
    At displacement speeds?
    At higher??
  3. AMG
    A bulb on a Hatteras LRC is probably optimized for speeds below 10 knots, and the speed gain will increase the range and economy at the same rate. In this case 3/4 of a knot. However you can probably lower the RPM and run the same speed as before with a little better economy. Most likely 10% better.
    But the real improvement is the stability you get from less pitching in my opinion.
