Privacy Matters Click for Burger Click for Westport Click for Delta Click for Ocean Alexander
lead blocks in bottom
Discussion in 'Hatteras Yacht' started by MissJameyLynn, Dec 14, 2011.
  1. MissJameyLynn
    MissJameyLynn New Member
    Charlotte Harbor, FL
    Recently purchased a 1975 58 yf , and found 6 large lead weights inside the port side storage compartment in the cockpit { they look like silver bars } has anyone seen this before and if so what would the purpose be ?
    It was the previous owner's piggy bank, because he knew lead prices were going to skyrocket and figured if he needed the money for fuel, he'd take the lead out! JUST KIDDING
    Yes, it's quite common and Hatteras as well as many others still do it to this day. It is to balance the boat, and to take a list (starboard or port) out of the boat by putting a little extra weight on one side or the other so the boat both sits level and run's level at cruise.
  3. NYCAP123
    It's called "ballast". You'll probably find some heavy equipment on the opposite side of the boat such as a gen or the galley that has to be compensated for.
  4. dennismc
    dennismc Senior Member
    Vancouver BC
    Jimmy Hoffa ?? at last
  5. NYCAP123
    Naw. He's under Giants Stadium in the Meadowlands.:cool:
